i'm not getting your question here, what i said it i would bet that your Vizio has less lag than both sony and samsung model TV's and you may notice more lag with a new sony or samsung TV and the samsung is more likely in my opinion to have more lag than the sony but they should be fairly close to the same in game modes based on previous year model's (2008/2009 models)
there is a chance that the Sony's may perform better this year, at least the higher end models because i've now seen some first hand evidence that at least the EX700/701 Sony models are most-likely using Sharps new X-Gen LCD panels and are not using the very Laggy S-PVA panels like Samsung does and sony has also used for the past few years and i'm sure will still continue to use in many low to mid level models due to owning 49% of the company that makes the S-PVA panels S-LCD
How would you compare the general differences between the Samsung and Sony pictures(colors, black levels, etc.)?
Very similar between similar level models
Do I run the risk of a panel lottery with the Sony?
No, Sony has never done a panel lottery and if you buy a specific model number Sony TV it will have the same panel in the TV as another model of that same size. they are much more consistent that Samsung and its just another sign to me of how samsung likes to cut corners esp on lower priced models.
Sony has used AUO panels in 2008/2009 model TV's but they tend to only put those in very bottom of the line sets where samsung has done that and worse in middle of the line sets like the B650's by not only putting AUO panels that are fairly good but also using CMO panels that are pretty bad in their TV's Sony never uses CMO panels
I read a statement from sony a few months ago that i wish i would have bookmarked, they said that in 2010 models they will be using only a very small percentage of AUO panels in their TV's and a decent percentage of new Sharp X-Gen panels in the upper end TV's and the majority of their TV's this year will continue to have S-PVA panels in them just like previous years but less than previous years due to the increased use of Sharp panels in top models due to the believed to be superior new X-Gen panel that sony also has a stake in its production due to a partnership on a new manufacturing plant in japan with Sharp.
I am very impressed with the backlit LED-LCD sets, I have a temporary 46 inch Sharp backlit LED-LCD in my room now (bought it over the weekend just to see the hockey game) and the picture is stunning (albiet the screen is too small).
