I just purchased a BDP-S570 and am reporting a serious flaw: absolutely positively no audio over HDMI to my Marantz SR7001 receiver. Has anyone else experienced "absolutely no audio over HDMI"? I will probably return the player.
More details:
(1) Software version M04.R.577
(2) Tried all four HDMI inputs on the receiver
(3) Tried two HDMI cables, one from Monoprice ("3FT 28AWG High Speed HDMI Cable w/Ferrite Cores"), one that came with my Oppo DVH-980H player
(4) Tried turning the power off and on to the player and also to the receiver in various sequences (this sometimes resets a balky HDMI connection, didn't help in this case)
(5) Tried several types of disks, including BluRay, standard CD, and hybrid SACD
(6) HDMI audio to the receiver works fine from two "universal" players, Oppo DV-980H and Pioneeer DV-610AV, with the same HDMI cables (I believe this narrows the problem to the BDP-S570)
(7) Audio can be transmitted from BDP-S570 to receiver using a coax digital connection (I don't consider this an acceptable work-around because of limitations of SPDIF audio)
(8) While the HDMI audio doesn't work, the HDMI video path through the receiver to the display (Sony SXRD rear-projection set) works fine; the display shows that the player recognizes the audio tracks on CD and hybrid SACD
More details:
