Originally Posted by Shrike645
You will get the lossy 5.1 tracks through the optical connection. Only HDMI will give you the lossless tracks that you were probably seeing with LPCM.
You can connect the optical out of the player to your avr and should get 2 channel SACD. Nothing better as that is per spec.
Upon further review ... over at the Yamaha 661 thread there's been some talk about this issue. Seems the 661 will pass whatever video it's given IF the HDMI handshake works. Some BD players must be set to force 1080/24; then the 661 passes it thru to the TV. Unfortunately, the Sony 570 does not force 1080/24 -- the only choices in setup are auto and off.
So I think I'll change everything back to HDMI path only, view BDs at 1080/60 and take advantage of the lossless MPCM pass thru, SACD audio etc., and sometime down the line upgrade my receiver.
Hope this info helps somebody else, and thanks for your responses.
barry
