I just hooked up a BD35 today. Found the connection to Access point and IP numbers no problem (wireless), however would not connect to the gateway. Called Panny, they said reboot the router, called Belkin, they said turn off the firewall. I turned off the firewall on the router, still wouldn't connect, rebooted and it connected.
Went to search for firmware updates, it wouldn't connect, tried again, it connected (no updates available)
Got netflix going, streamed Wall-E, had 5/5 bars on signal strength, with a quality of about 4 out of 5. Played for 37 minutes, then froze. Got it going again quickly, played the rest of the movie freezing about 5 times, only one time would it not connect.
Looked at the Manual, said 6 MBps, I only have 5 (DSL) with an average speed test of 2.5 (middle of the day). Called centurylink to get upgraded to 10 MBps ($5/month), will be turned on Friday.
Starting to wonder if it's the router settings, the router, the speed, or just netflix.
I've had two other Pannys that still work great, so I'm hoping I'll figure this out.
