Originally Posted by Vortex3D
I know this doesn't help now. For me, I always make one or two sets of backups especially on games that take a lot of hours to play. I never trust any online storage because there is no way for me to control where they save my games especially if the online storage auto syncs with my console.
Note about Mass Effect 2 or 3 (can't remember ME1) saves on their saved game files on X360. The saved file doesn't not allow being copied but only be moved. This means it only allow you to keep one copy of your saved game file.
As for X360 online storage, there are two ways it stores your file. If you never copy your save game file by hand to online storage, it just "sync" your files not quite in full form. If you manually copy your files to online storage, then it has a physical files copied there. Since ME2/3 doesn't allow direct copy of the saved game files, you can only hope whatever "sync" to the online storage, it has a complete set of the saved file data. The reason I think X360 by default doesn't copy the physical files is it also keeps a local online storage file on the hard drive and has fixed file size. If you have multiple Gamertags, all of them will be sharing the same local storage file which will run out of space before they all reached their limit. (I have tested this and proved it). The only way to ensure my saved game files all 100% sync all the files contents is manually copy each file to the online storage. That way, I can even delete the saved game file on the local hard drive and the online copy stays on the online storage.
On PS3, ME2/3 keeps two saved game files, one for your game progress which is not locked and other file for your total kills or data that are linked to the ME trophies. In other words, you cannot manually backup the ME "trophy" save file but you can backup your game progress to USB storage. You will need online storage to backup the ME "trophy" save file because it's allowed. If you have multiple separately playthroughs, game progress saved file get individual save files but the separate playthroughs share the same "trophies" save file.
Thanks. I'm going to start backing up all my files that are "big game" files, like ME, Oblivion, etc. I checked my other Xbox, but it's also blank, as is my cloud storage. What a bummer. I was really excited to end the game, and I'd even ramped up my MP to make sure I was at 100% across the board when I'd finish the game. My MP save is still there, but I'm guessing that's stored on some ME server?
Originally Posted by AutoWobble
I've got a weird question about the Leviathan DLC and I was wondering if anyone had an answer for me, as I haven't beaten the game (but I have completed Leviathan):
Near the end of the DLC, when you crash land onto the ship, before you dive down into the ocean, there are a bunch of artifact spheres in some of the tents you search. I read somewhere that you should destroy those spheres because they impact your game later on, but I completed the DLC without destroying them and I want to make sure I'm not taking away a possible good ending later on down the line. Do you know if it matters if you destroy the spheres or not?
Good question. Warning: Spoiler! (Click to show)
I think I destroyed all of them, even though I had no idea what they were there for. I just did a few minutes of digging but couldn't find anything on whether or not destroying them does anything. If you find anything, let me know!
_JR
I wonder if there's some way to set up all your choices and configure a save and then load it onto your Xbox? Like some PC hack. Who knows...
