AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Help hdmi cable wont work with Panasonic AE4000u
post #1 of 12
I just got my panny ae4000u today and tryed to hook it up to my ps3 i have a 35foot hdmi cable running from my yamaha receiver to the projector and it wont work so i toook the ps3 and placed it rite under the projector with a 6feet cable and it worked fine is the cable to long or do ui need to bost the signal please help this it my first projector does the ps3 and my receiver need to be close
post #2 of 12
I would say it may be a problem with the quality of cable on your 35'. Do you know what the cable is rated for? You could also try taking your receiver out of the mix and running the 35' cable directly from your source to the PJ as a test.
post #3 of 12
this is the cable i bought and i did try running the cable from the ps3 to the progector but it still didnt work
Dayton Audio Signature HDMI video cables are ATC certified for the purest picture (supports up to 1080p) and digital audio signals. The exclusive RF-Blok cuts out unwanted RF interference. Unlike other HDMI cables, Dayton cables use larger, shielded twisted pair wires (24 AWG), gold plated connectors, a solid metal termination housing and a braided cable sleeve for cable quality that is second to none. For a secure cable connection
post #4 of 12
24 AWG is not large, I don't know what you paid for yours but the cables in the link below are 22AWG. So much for Dayton's claim that other cables use smaller wire than 24. Reading the rest of their spiel, there is nothing special in their cables. It 's advertising hype.
http://www.monoprice.com/products/su...02&cp_id=10240
And the fact that it worked at 6' just reinforces what we have been saying in this forum time and again, HDMI can be finicky over 12'. The quality of the cable will help in most normal cases. Occasionally, and HDMI extender is required, usually in situations where the run is extra long or the source equipment is putting out a weak signal.
post #5 of 12
Try the 35ft cable directly from the PS3 to the projector!
post #6 of 12
Wire gauge is practically irrelevant in this application.
post #7 of 12
I have a Monoprice 50 foot cable and it works fine. Like you, my older one would not work.
post #8 of 12
thanks for all the help i got a bad cable from parts express i got a new cable yesterday from b buy and projector is woking great are the mono cables really good has anyone ever got a bad one
post #9 of 12
Ouch! I bet that cost a premium...
post #10 of 12
yes that 35' cable cost me 213.00 dollars
post #11 of 12
For future reference, visit www.bluejeanscable.com and save your money while purchasing high quality cables.
post #12 of 12
You overpaid by enough to buy a BluRay player!
