AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung LED UNxxC6300, UNxxC7000, and UNxxC8000 Owners Thread
Official Samsung LED UNxxC6300, UNxxC7000, and UNxxC8000 Owners Thread - Page 211
post #6301 of 6307
Originally Posted by Tom Riddle View Post
I wish I could, but I don't know how to fix it.
Please help me, show pictures of the service menu with the factory settings.
Great thanks.
post #6302 of 6307
Shoot me how to get in and a screenshot of you current settings.
post #6303 of 6307
Is there a tilt mount on today's market that's suitable for the UN55C7000?
I finally need to mount my TV and so need to pick up a suitable mount that's compatible with my TV.
post #6304 of 6307
Just about any universal mount should work. Just make sure that it is made for the screen size and weight of your tv.
post #6305 of 6307
What about the screws required on the back of the TV? Is there a particular depth to them? I've read of some incompability with what come with Sanus mounts for example.
post #6306 of 6307
The owner's manual should give you the max depth. If the mount doesn't have the screws needed, you can purchase them at Lowe's.
post #6307 of 6307
Take a toothpick or wooden skewer and place them in the mounting holes on the back of the TV. Mark the depth with a marker. You cannot go deeper than than. With the thickness of the mount, you should come out just find with screws that are just shy of the depth you marked.
