AVS › AVS Forum › Audio › DIY Speakers and Subs › Twin Towers BUILD LOG
Twin Towers BUILD LOG - Page 4
post #91 of 615
hehehe now youre seeing it my way... but then, how am I supposed to get 7 speakers wrapped around me... I only have 4'x4' left for my listening position...
hehehe ... ya... I should put these on eBay when I'm done with them
post #92 of 615
post #93 of 615
Dood,there's two words in my head right now....
"inadequacy syndrome"
post #94 of 615
I am just thinking why not 4 THT's or 4 easybuttons.
The room/house/neighborhood just isn't big enough to need what you're building.
Hell the room it isn't big enough to need two THT's
I have twice that space and I can make dishes rattle one floor up with 2 Paradigm DSP 3400's, I can't even imagine how my two Easybuttons will sound next week when my drivers arrive.
If a pregnant woman sat in that room for 2 mins the kid would come out cross eyed.
I am watching this with shock and awe.
Crazy in a crazy cool, but really overkill crazy way
Jeff
post #95 of 615
hah I keep tellin everyne it reminds me of Lord Farquad!
post #96 of 615
Jeff
( thats all I need to say about that )
post #97 of 615
Talk about filling a room with bass.............WOW!
post #98 of 615
Or filling a sub with a room....
dbl
post #99 of 615
dbl
hehegha!
post #100 of 615
post #101 of 615
I hope placement isn't an issue! LOL!
Monsters! Good luck man!
dbl
post #102 of 615
dbl
believe it or not, theyre not that hard to move!
post #103 of 615
LOL
Seriously,add major major BRACING to these huge boxes. I would brace each 12 inches or so.
The baffles on such huge boxes should at least be 2.25" thick,and use bracing on the inside.The cabinets of any sub and speaker should be as inert,dead and flex the least possible.
Bass SQ starts with the proper driver installed in the proper volume cabinet,this providing the walls of the cabinet produce the least leakage possible(within reason).
Way to go on the huge subs. The cat will be scared! Our cat went crazy after I tested only the MJ18's near full excursion! Lets not talk LMSUltra/5400 going near excursion limits.
Subs are about having fun and overdoing.
post #104 of 615
Ya KW,
I would add about 2 dozen more 2x4s to those boxes.
There has to be some serious flex with panels that large.
That room shot with both boxes in there has to be in the hall of fame!
OR the one with your wife IN the enclosure!
post #105 of 615
Did you ever consider the DTS-10?
It will give you the single digits without all the floor space.
post #106 of 615
i would seriously think about taping the windows in that room just in case the glass breaks when you fire those subs up.
post #107 of 615
Originally Posted by jpmst3 View Post
Ya KW,
i would get some half inch plywood cut into 2 inch wide strips and honeycomb the interior walls.
post #108 of 615
I think you would have been safe building just one.
That way, all you have to do is fire the subs inside of it, and you'll have room for an LCR on one side and the surrounds in the back.
You can even put your screen in there.
It would need a door however.
post #109 of 615
i agree with the comments that many more internal braces are required or you will be losing a lot of "impact" to cabinet flex. since wood is relatively very, very strong as measured by compression against its length, you could use a bunch of 2x2's. i'd try to get a point of bracing every foot or so a few braces uses the # (tic tac toe shape) should improve things a lot and help keep weight down.
we are all curious to know where the heck you are going to put these things.
enjoying following your build...
post #110 of 615
"i would get some half inch plywood cut into 2 inch wide strips and honeycomb the interior walls."
with the narrow edge on the walls right, in order to minimize flex?
post #111 of 615
Why am I getting a Back To The Future flashback?
You've got "protable" IB's there!
dbl
post #112 of 615
yep... thats the idea.
post #113 of 615
i think its safe to say they aint going in his bathroom or his kitchen.
post #114 of 615
unless there is a door that is open to almost as tall as the ceiling, how are they even going to be tilted in order to me moved?
also, i like the idea by mr. winters in #107. something like that combined with a few braces across the beast should improve things significantly. or, if you want to get really simple and don't mind the weight, just pl some 2x4 with the 2" side along the walls that may flex. a big "X" extending out from the current reinforcement point may be good enough...well, it should improve things a lot.
post #115 of 615
This thread reminds me of a 70 chevelle with a 6 banger in it.
post #116 of 615
more like an ls9 in an oil tanker.
post #117 of 615
how do you mean? your comment strikes me as kicking sand in his face kanaris.
post #118 of 615
Not really.... it's my point of view..
post #119 of 615
well I've enjoyed all of these comments.. my "wife" too
I'm glad we're all having fun here, I started off posting in 8 forums..I am down to 5, and one more might be getting the axe as some people have nothing better to do than... well... we're havin fun over here... so thanks again guys!
post #120 of 615
"Not really.... it's my point of view.."
i see your point and it makes logical sense, but give each soul a chance...self proclaimed, he is still experimenting...let's give him that...cool?
