Hi
I'm new to the forum so please don't be to hard on me.
I recently got a new TV the "Philips 42PFL7404H/12" and don't get me wrong this thing looks incredible when playing HD stuff, and SD looks ok. but the input lag during gaming is quite bad. I checked a site called digital versus, and it's 32" younger brother scored an average of 33ms input lag, whether this test was done from an interlaced or progressive source is beyond me, but either way i know the input lag is bad from personal experience playing games. so I've been looking for an external unit to try and resolve the problem. I've found a few units that look like they might do the trick but keeping it within budget looks tricky (about £200...$420ish)
The device (whichever sounds best really) would be used with mostly older consoles such as the Saturn, megadrive, PlayStation, PS2 etc all of which running mostly through rgb scart leads.
I've read up on the DVDO edge and it looks like a fantastic little device but it's slightly out of my price range at $500/$600. Then there's the xrgb series which is not only notoriously hard to find, but also (from what i hear) has slightly more lag than the DVDO edge.
I've found a few that look quite good but haven't been able to find much feedback on them, there's the LENKENG LKV391 which i can barely find any information on regarding input lag/latency times, but the thing that drew me to it was the low price and the fact that it's got a scart input directly on the box (convenience)
Then i came across the Atlona AT-LINE-EX which touts such things as "No audio or video delay! Converts in real time" and "less than half a frame delay" which theoretically makes it better than the dvdo edge in the latency/input lag department, only problem is, the user reviews online about the at-line unit aren't that good... overheating issues etc, but if they've sorted out these issues then i know which one I'll be getting.
Any help/info regarding these or other units would be much appreciated as I'm struggling here, also does anyone have any info regarding the VGA input on my model of TV and if using it avoids post processing issues.
thanks, Dom.
thanks, Dom.
