I was fortunate enough to be an alpha/beta tester for the upcoming Meta 2.0 application and wanted to announce that I will be releasing an extensive preview of it on Friday at my site, theHTPC.net.
If you're not familiar with Meta, then I will repeat what its developer states about the current version from his site, www.themetabrowser.com:
I will save everything else for Friday, but will say that even unfinished, it is an amazing application.
If you use Twitter, Follow Me and you will get notified as soon as the preview is released. Otherwise, just check www.theHTPC.net on Friday.
Meta 2.0 will throw out some of the limitations the current version imposes, primarily, what front-ends it provides metadata and images for."Meta is an all-in-one solution to retrieve metadata for Movies and TV shows through the available APIs of themoviedb.org (TMDb) and thetvdb.com (TVDb). It was primarily created to provide metadata for what I believe is one of the best Vista Media Center plugins created, Media Browser, but can be used by any application that utilizes MyMovies.xml for movies or Series.xml and corresponding metadata folder for TV Episodes."
