Originally Posted by
thedoc46
Hi,
My setup is as follows.. PS3 Slim as my Bluray, Yamaha RV-X2700 as my receiver and TC-P50G25 as my TV. (not rec'd yet so hence my question)
Both TV and PS3 are HDMI 1.3a , but my receiver which will be acting as a pasthrough is only HDMI 1.2a
Given the specs below, will I lose any quality if I go through my receiver?
Namely Auto-Lipsync Correction feature (8.3.2, 8.9) & xvYCC Enhanced Colorimetry (6.7.2.3) ?
Obviously for sound I'll just go with LPCM from the PS3, but my question is will my TV be getting a lesser quality picture because my receiver is 1.2a only? If I go directly from the PS3 to TV, my understanding is the optical output on the TV downgrades itself to 2.0 only? and even if it was 5.1, i'd still not get TrueHD...
Advice welcomed.
1.3a 2006/11/10
Cable and Sink modifications for Type C (Table 4-20, 4.2.6)
Source termination recommendation (after Table 4-15)
Removed undershoot and max rise/fall time limits (4.2.4).
Modified slope of TP1 and TP2 eye diagrams (4.2.4, 4.2.5)
HDMI cable assembly AC-coupling support required (4.2.6)
CEC capacitance limits changed (4.2.10)
Valid range for RGB video quantization added (6.6)
Added audio sample rate exceptions for ARC (7.3, 7.3.1, 7.3.2)
Added Audio Rate Control Overview (7.11)
1.3 2006/06/22
Significant new features:
- Type C Mini-Connector (4.1.9.5, 4.1.9.6)
- Cable Categories 1 and 2 (4.2.6)
- Deep Color [4:4:4] (6.5, 8.3.2)
- Reference Cable Equalizer (4.2.3.2, 4.2.5, 4.2.6)
- Higher-speed single-link (4.1.2, 4.2.3,through 4.2.6, 8.3.2)
- xvYCC Enhanced Colorimetry (6.7.2.3)
- Gamut Metadata transmission (5.3.12, 6.7.3, Appendix E))
- DST audio format (5.3.10, 7.6.3)
- High-bitrate compressed audio formats (5.3.11, 7.2.4, 7.3.3, 7.6.2)
- Auto-Lipsync Correction feature (8.3.2, 8.9)
Updated normative reference from CEA-861-B to -D (1.2, throughout).
Updated Overview for new features (3)
Several minor editorial (throughout)
1.2a 2005/12/14
Changes to CEC supplement (see supplement for details)
Eliminated IOFF and made VOFF normative (4.2.4)
Changed CEC resistance to 5 ohms (4.2.10)
Clarified DVI device discrimination (8.3.3)
1.2 2005/08/22
Removed limitations on Type A connector usage (4.1.2, 6.1)
Required new connector mechanical features, optional in 1.1 (4.1.9)
Required Sink support for future AC-coupled Sources (4.2.5)
Add note regarding maximum ratings of Sink (4.2.5)
Clarified Cable Assembly use of +5V Power (4.2.7)
Removed incorrect testing method for DDC capacitance (4.2.8)
Clarified when separate CEC lines on inputs are allowed (4.2.10)
Add maximum resistance spec for interconnected CEC line (4.2.10)
Remove CEC leakage current limit while in standby (4.2.10)
Relaxed YCBCR output requirement for RGB devices (6.2.3)
Added support for additional video formats (6.2.4, and 7.3.3, 8.2.1)
Corrected sample rate requirement from 1000 ppm to ±1000 ppm (7.2.6)
Clarified use of Speaker Allocation Data Block (7.4)
Added support for One Bit audio (7.9, and throughout)
Clarified exception for 640x480p (VGA) declaration in EDID (8.3.4)
Loosened requirement for duplicated DTD declarations (8.3.4)
High-Definition Multimedia Interface Specification Version 1.3a
HDMI Licensing, LLC Page iv
Added recommendation for setting Supports_AI (9.2)
Clarified the behavior of Repeater to Sink with Supports_AI (9.3.2)
Clarified rule for DVD-Audio ACP Packet transmission (9.3.5)
Additional minor editorial (throughout)
