AVS › AVS Forum › HDTV › HDTV Recorders › The Official AVS TiVo "Series4" Premiere topic
The Official AVS TiVo "Series4" Premiere topic - Page 53
post #1561 of 2524
Originally Posted by tightrope View Post
Must additional (external) storage be purchased exclusively from Tivo? Or can I use my own drive and connect it to the eSata port? Thanks in advance
Doesn't have to be purchased from TiVo but MUST be the Western Digital My Book AV DVR Expander 1TB. It is the only one that the TiVo will allow to be connected.
Good luck finding one...
http://www.amazon.com/Western-Digita...dp/B003MVZ60S/
post #1562 of 2524
The Western Digital My Book 1TB AV DVR Expander is easy to find. It's just hard to find one at a decent price.
post #1563 of 2524
Cool, thanks for the info and the link
post #1564 of 2524
Originally Posted by WS65711 View Post
The other thing that pushes my buttons is the attitude of several members of this forum. That being "Most people don't require this capability, so neither should you".
For my part, I never said that. My point was merely that it is reasonable to expect hardware vendors to remove features that the majority of their customers do not demand in an effort to reduce manufacturing costs.
post #1565 of 2524
I understand that not everyone cares that OTA image quality is superior.
I prefer the word "better".
post #1566 of 2524
How about "better for now"?
post #1567 of 2524
I can see you point of view. In fact I have seen the results of trying to keep costs down by removing unpopular features. But, lucky for a few people, there is a market for TV, Blu-ray and AVRs at the high end for consumers like me that want the features supplied once you cross the $300 line.
One side of the "market coin" is consumer demand for low prices. The other side is looking for features and competition. Pick a company that has a product line that is not associated with a retail outlet like Sony, Panasonic or Sanyo. See if Walmart carries all their products or just the low-end. It's natural to want to save money, but choice is still alive and thriving.
post #1568 of 2524
................ I understand that not everyone cares that OTA image quality is superior. ..............
Here on FiOS, OTA is identical to what is broadcast on FiOS. I can record programs from OTA and FiOS and they look the same and also take up the same amount of hard drive space.
post #1569 of 2524
Interesingly enough, my Comcast does the same thing. My HD recordings of the Super Bowl from Comcast and OTA use the exact same bit-rates and the recorded files are essentially the same size. I recorded one on my PC and one on my Tivo, then transferred the Tivo recording to my PC so I could compare. I edited the files so they start and stop on the same frame.
post #1570 of 2524
That's a ridiculous price-gouge trying to take advantage of the post-flood HDD shortage. The list price on the WD web site is $160 but it is out of stock. I love the joker trying to sell one for $10,000. That must be a misprint on the website.
No telling when the supply will right itself. Initial estimates last year were shortages through Q1/12. I haven't seen any updates. The drives I track for A/V use are still running 1.5X pre-flood prices and have been holding steady there for weeks.
post #1571 of 2524
I came home today to find that my TiVo had rebooted. I'm not sure if it received an update. The current software version is 20.2-01-2-748.
I also received my email for completing the survey. I'll take time tonight to complete it.
post #1572 of 2524
I show 20.2.01-2-746 so maybe something changed.
post #1573 of 2524
746 is the regular Premiere
748 is the XL Premiere
758 is the Elite Premiere.
post #1574 of 2524
Hi, I have very much enjoyed my Premiere since I received it a few weeks ago. Now I am thinking of using the Tivo Desktop application on my PC. I read somewhere that the TivoToGo value in the System Information section should be "a,a,a". However, it shows "i,i,a". Does anyone know how to change it to the right value? Thanks in advance.
post #1575 of 2524
Is Video sharing & Enable video downloads enabled (checked) in your account on TiVo.com
https://www3.tivo.com/tivo-mma/dvrpref.do
Have you entered Your media access key into the software?
https://www3.tivo.com/tivo-mma/showmakey.do
You will need to force a Network Connection and it may take 24 hours before enabled.
post #1576 of 2524
Thanks for the quick response Bryan.
I did enable Video sharing & Enable video downloads yesterday evening. At the time the TivoToGo was showing "i,i,i". Now it is showing "i,i,a", I guess it's going in the right direction . It has not been 24 hours yet, I'll check again later.
Now how do you force a Network Connection
post #1577 of 2524
Now how do you force a Network Connection?
TiVo Central > Settings & Messages > Settings > Network & Phone > Connect to the TiVo Service now
If it needs a reboot after, the Last Status will say "Restart Pending" otherwise it will say " Succeeded"
post #1578 of 2524
One unresponsive unit I can ignore, but I have now had it happen twice with the same problem. I turn the unit on (from Standby). After the first screen displays I hit the button to give me a full screen of TV. The result is a blank screen without audio. I'm on cable and have a cable card. The unit shows a yellow circle in response to any remote button. I have waited 30 minutes in case it was just thinking. Finally, I pulled the power for a few seconds and reapplied power. Everything was then back to normal with no loss of data or configuration. This is only the second time in two or more months. No other problems. The unit is on a UPS and there have been no power failures. It records 2.5 to 3.5 hours daily with no problems, and only one show at a time while in Standby.
I'm only doing this post in case some other Premier owner has seen this.
post #1579 of 2524
Any particular reason you put it in standby?
Do you need to reset the parental controls?
post #1580 of 2524
I hate the red circle. My Tivo is located under my TV by six inches. In standby the red recording circles are off also. I guess I could just block the front. Next time.
post #1581 of 2524
Joe-
Just guessing.. this could be something with the way your CableCo handles CableCards? Maybe it's losing CableCard communication somehow when it's in standby?
Also, there is a setting in the configuration that you can turn off the indicator lights, but I think it turns them ALL off.
post #1582 of 2524
You can also turn off the front lights from the settings menu.
post #1583 of 2524
Yeah - I really like that fact and I'm surprised it's available. I wish all manufacturers (receivers, blu-ray players, etc) would offer such.
post #1584 of 2524
Joe-
Perfect. No more lights.
If the unit is in standby, the TiVo button brings up TiVo Central and the video in a small box with audio. Plus I have never lost a recording. The blank screen happens when I hit the "Live TV" button. There is always a slight pause when switching modes. But it's fine now since no LED to bother me.
post #1585 of 2524
I agree. However my Sony S570 Blu-ray is totally dark when off. I have an old Toshiba RX-50 DVR that has an "eco" option that kills the front panel when off. My Yamaha AVR is dark when off also.
post #1586 of 2524
I don't care (to a large degree) if they light up like a christmas tree when turned off. It's when I'm using them I want darkness. Either in the den when they are in my line of sight or my dedicated room where they might reflect onto the screen.
post #1587 of 2524
Cardboard, painted flat black, is wonderful. If you really want to be distracted, get a PViX DVR. It scrolls the channel and time remaining when it is recording. I guess that made sense for somebody.
Possibly my router and modem qualify as a Christmas tree. More cardboard.
post #1588 of 2524
For those of you noticing software updates etc, especially Comcast customers in the San Francisco area, it may be preparing for xfinity VOD:
http://www.engadget.com/2012/04/10/t...unch-bay-area/
Check your zip code at http://www3.tivo.com/products/source...ast/index.html
Feature works fine by the way. Read this thread over at TCF starting around the bottom of page 7 for first hand reports, screen shots etc:
http://www.tivocommunity.com/tivo-vb...=469328&page=7
post #1589 of 2524
These work rather nicely... along with electrical tape (my personal favorite).
http://lightdims.com/
post #1590 of 2524
Sweet!! Thanks!!
  Back to Forum: HDTV Recorders
