Originally Posted by aaronwt
Do you have a lot of things set for "Keep Until I Delete"? That is a typical symptom of too many things set for KUID. Since it has to calculate the space it needs in advance and will delete things sooner because of it. KUID should be used very sparingly. It's rarely if ever needed.
OK - I've adjusted most of my season passes to "until space is needed". Will the Tivo now let the HD fill past 80%? Will it let it get into the 90's?
