Agreed, if all he needs is an OTA tuner the Tivo is not a good choice. As a Cablecard tuner it's a great choice for a cheap STB.
post #1651 of 2514
6/9/12 at 6:53am
and I've been intending to pull the hard drives on the others and sell them on eBay for 10 or 15 bucks each. When I moved to my present location, Comcast did the install when I was away and my grandson was there. The installer set up a Motorola 3400 cable decoder box with a 500gb tuner (the largest storage available from Comcast), put a cable card into my Tivo, split the signal and so forth. I thought briefly about having Comcast pick up their box, but changed my mind because the units both work perfectly and I can switch between them with the TV remote giving me a total of 6 tuners and 3.5tb of storage (500gb on the cablebox, 2tb on the Tivo and an extra 1tb with the WD DVR Expander). I was told that the Tivo software was limited to 2tb total, but the Expander works for me and DOES increase total capacity to 3tb. I then called Comcast telling them the installer made a mistake and pointed out their expense to send out an installer again, she offered to let me keep the current setup without an extra charge which saved me $10 a month. They already charge me through the nose for enhanced internet (their fastest service at about 30mb/s speed) and cable with the premium channels, so the discount wasn't a big deal. I never intended to have them pull their cablebox, I knew they would negotiate. Over the years, our local cable changed hands 4 times, finally ending with Comcast. Each time I called them to pull their service so I could switch to Dish, knowing that the phone rep's had the authority to offer discounts....and each time, they did...after a bit of haggling.
