AVS › AVS Forum › HDTV › HDTV Recorders › The Official AVS TiVo "Series4" Premiere topic
The Official AVS TiVo "Series4" Premiere topic - Page 110
post #3271 of 3305
Originally Posted by somelogin View Post
Anyone ever going to answer me as to the best way of watching shows after I do transfer them to a computer (as in watching them AFTER I no longer own the TiVo)? Surely any method possible will be worse quality for HD shows than when still on the TiVo. But I guess the main thing is I just care about not losing some shows which will never be on again, such as Leno.
I think just about everyone has you blocked.
post #3272 of 3305
Write them to a DVD?
cb
post #3273 of 3305
Western Digital Live will play your media files in their native format if they are available on the network.
You can also get an AppleTV, jailbreak it and install XBMC on it (google how to do it) and you can get the same capability but only in 720p.
post #3274 of 3305
Here is what works for me:
TiVo Desktop: I use this to transfer shows from the TiVo to my PC. It also installs the proper codec and de-packager to allow Video players on the PC to play .tivo files.
VLC, a free video player: I use VLC to play .tivo files. (You may need to purchase the TiVo Desktop to enable VLC to play the files, but you can try it with TiVo Desktop first to see if you need it.)
My Sony 55" LCD is connected to my PC via DVI/HDMI as my second monitor.
I output the audio from the PC via optical cable to my Denon receiver for 5.1 sound.
There is NO loss of quality from the broadcast stream, as the transfer is a complete digital copy.
Greg
post #3275 of 3305
Odd. Did this thread suddenly lose several days worth of posts?
post #3276 of 3305
Yes. Too bad we don't know why.
post #3277 of 3305
Massive software hiccup or mod-intervention.
post #3278 of 3305
There were several helpful posts by myself and others, I do not understand why those were deleted. I am a bit angry about it.
post #3279 of 3305
As always, when a problematic post(s) is reported and removed by staff, any posts that quoted or directly replied to it/them are also removed.
Now, back to your regularly scheduled TiVo discussion... :)
post #3280 of 3305
Thank you.
post #3281 of 3305
I don't recall anything very contentious. As Kelson speculated, there could have been a software malfunction or maybe a hardware failure with no backup. Whatever happened, it would be nice to hear some explanation.
post #3282 of 3305
Many, many thanks for the intervention.  I think that I can speak for other followers of this thread in saying that it was long overdue and is greatly appreciated.
post #3283 of 3305
I just picked up a used Premiere XL and Netflix does't work which seems to be common now. I also get the "We're having trouble playing this title right now. Please try again later or select a different title." aip-702 error. I also had no luck with TiVo or Netflix tech support resolving the issue. If anyone finds a fix, please post it!
post #3284 of 3305
Try asking at the TC forum. http://www.tivocommunity.com/tivo-vb/forumdisplay.php?f=67
post #3285 of 3305
Thanks Joe. I did look in that forum (TiVo) and others had the issue but no fix. But I did post a new thread on it to see if anything has changed.
post #3286 of 3305
We've used it on a Premiere as recently as December 2013... but we no longer subscribe to Netflix. There just wasn't enough worthwhile stuff that we wanted to watch . . . rolleyes.gif
post #3287 of 3305
I've streamed Netflix on my Premiere and Premiere Elite as recently as last month without an issue.  (I'm currently only subscribed for BRD by mail.)
I agree with Joe that posting on the TCF is the way to go.  But be sure to include all the parameters of your system, including whether wired or wireless networking, type of ISP, router, etc., so that others can better assist you.
post #3288 of 3305
Good point Chi_guy, the more info the better. I have tried all of the router, modem, ports, and etc. , so it doesn't seem to be a connectivity issue, but who knows. I am wired with a very good provider and have had zero problems with my other streaming devices. A couple of people were having the same issue and it just went away for them. TiVo support told me that the last 2 software updates has caused Netflix problems with a number of people. But others are fine. Go figure.
post #3289 of 3305
Comcast, Del. County Penna. just had a channel line up change. How long does it usually take before Tivo updates the channel line up? Of course the some of the channels that are affected are the ones that I record.
post #3290 of 3305
It depends, sometimes I see changes days in advance, other times I have to submit the changes, which are usually updated within a day or two. Tribune Media (Zap2it.com) provides the TiVo Guide data.
Check Tribune Media to see if they have the changes already, if they do just force a Network connection
http://tvlistings.zap2it.com/tvlistings/ZCGrid.do?aid=zap2it
If they do not have the updated line-up Submit a request and list a few of the changes and ask they contact Comcast.
http://www.zap2it.com/services/site/help/zap-faq-contact-channel,0,5059403.htmlstory
TiVo has their own Report a Lineup Issue, but I find it quiker to report directly to Zap2it.com.
http://www.tivo.com/lineup.html (page looks odd to me, where did the site design go???)
post #3291 of 3305
I appreciate the links. Zap2it is still wrong...mostly, although they have one of the channels updated. Tivo wants you to do their work for them and itemize all the affected channels and tell them exactly what is different. You got to fill out all this information but the instructions they post for finding the information is in a pop-up box that won't expand and blocks off the location of where to find the information. More problems than what it's worth (to me). But I will keep an eye on that zap2it page. I like that a lot.
post #3292 of 3305
The people at zap2it were great. I contacted them and they responded immediately, then changed their channel line up within 24 hours. By the next day, I got an update from Tivo. Still haven't been able to sync my TiVo to their site. Keep getting an error when I log on to the TiVo site.
Anyway, thanks for pointing me in the right direction.
post #3293 of 3305
Did you get this email:
Sent: Monday, March 03, 2014 09:11
To: joekustra
Subject: Changes Coming to Zap2it
Dear Zapit TiVo users-
We know there have been issues accessing the TiVo functionality on Zap2it’s TV schedule and we are excited to announce changes are coming.
Mid-month a new and improved Zap2it will be released, featuring a sleek new design, bold content and streamlined navigation to help you find what to watch and where to watch it more quickly. TiVo functionality will temporarily be removed from the Zap2it TV schedule while we work directly with TiVo to get the TiVo functionality added back into the grid in a more user friendly format later this Spring.
We appreciate your patience and look forward to sharing the new and improved Zap2it with you.
Best,
The Zap2it Team
It could be related.
post #3294 of 3305
Will the TiVo Premiere actually play any .MP4 files? I had never tried before today, but I have been unsuccessful.
My son (home for Spring Break) brought some .mp4 files (movies) home on his notebook. I copied them to the "My Tivo Recordings" folder created by TiVo Desktop, but the TiVo failed to see any of them. I tried a few other .mp4 files that I had on my computer, all with the same result. I found that I could use Roxio to convert to .mpg files and the TiVo would see them and play them, but that is a v-e-r-y long process.
Anybody got any hints?
post #3295 of 3305
use pytivo to push them, pytivo will convert them.
post #3296 of 3305
Thanks.. I guess. Python, pyTivo, and whatever else seems to be MUCH easier said than done. Been banging my head against the wall for three hours now, unsuccessfully . . .
post #3297 of 3305
From: Zap2it Feedback [[URL=mailto:feedback@zap2it.com]mailto:feedback@zap2it.com[/URL]]
To: joekustra
Best,
The Zap2it Team
No, Joe. I never notified them that it didn't work for me. I never had time. They corrected the issue so fast that there wasn't a need to sync with their site.
post #3298 of 3305
It's PAST mid-month and Zap2it still hasn't updated its Web site and it STILL won't work with TiVo....
post #3299 of 3305
The site doesn't seem different but I can schedule shows.
post #3300 of 3305
Just tried again, and, when I try to link with TiVo, it won't connect. At one time, I was linked with TiVo, but that no longer seems to be the case.
EDIT: This is the error message I get -- "Sorry, but we encountered an error while processing your request. Please try again later. "
Edited by bierboy - 3/24/14 at 11:31am
  Back to Forum: HDTV Recorders
