Originally Posted by deltadube
Hi again CR13
was chatting with a buddy
he is recommending that i get 2 xpa 100 250 watt amps.. mono blocks about 379 i think
would that be best? more interested in power for music.. denon has enough for movies .. i dont really crank them.. just veg and watch..
music is where i love to crank up some good tunes
i got the blues.. taj mahal..
cheers..
Hi again CR13
cheers..
About your question on what to buy: two XPA-100 (250W) monoblocks that will run for $758.00 (pair), or one the XPA-2 (300W per channel) for $ 679.00? Well, if it was me, I would pull the trigger on the XPA-2 anyway. More power for less money.
In addition of power/money thing, my additional logic is: growth. You see, the XPA-2 can be used in a bridged configuration @ 8 ohm "only". So, down the road you can add a second XPA-2 to your system. In other words, you will have a dedicated XPA-2 for the right channel and the other one for the left channel. But remember, you can only do that if you are using 8 ohm speakers. Which is your case already with the Energy Veritas.
If music is your thing, oh boy a pair of XPA-2's will blown you away!!!
On the Emotiva link provided by BarracudaDelGato, you will see the number to call Emotiva for international orders: 1-877-366-8324 or you can contact them by e-mail: sales@emotiva.com
They are really good responding to e-mails, so you will not wait for long to receive a response. Just keep in mind of the holidays and I'm not sure if they are going to be open tomorrow (12/24).
One more thing to consider (I know that you already mentioned that you want "new"), but you can ask Emotiva if they have "B" Stock on the XPA-2. You can save a bit there that might help you to offset part of the importation costs. Just something to consider.
