The only caveat I add is that 3 db can make the difference between clipping and not clipping.
Featured Stories
Topics Discussed
Related Forum Threads
- Marantz AV7005 and Emotiva XPA-5 Last post on 5/18/13 at 12:45pm in Audio Gear
- Emotiva XPA-5 Last post on 5/5/13 at 5:53am in Audio Gear
- Emotiva amp connected to my Yamaha AVR, would this help any? Last post on 4/25/13 at 12:09pm in Receivers, Amps, and Processors
- Need a 5ch Amplifier - Parasound Halo A52, Emotiva XPA-5, or something else? Last post on 4/15/13 at 3:57am in Receivers, Amps, and Processors
- Emotiva XPA-5 Last post on 4/14/13 at 8:03am in Audio Gear
Related Reviews
Official Emotiva XPA-5 Owners Thread - Page 21
Gear mentioned in this thread:
- kbarnes701
- Trader Feedback: 0
- offline
- 10,414 Posts. Joined 1/2008
- Select All Posts By This User
Ya there's not much audible difference between the Integra dtr 40.3 and the XPA-5 that I can hear. Integra does have pretty good sound though. Reviewers have used them and their processors a lot. Good brand. The only way I notice a difference is that using the XPA-5 is a bit louder then the Integra amp. So the Integra vol is set to 60. Speakers connected to Integra. It's loud. Keep the vol at 60 and connect the XPA-5 amp. Connect speakers to XPA. Sound is a tiny bit louder but overall sounds similar. So close I can't tell a difference.
If I played at loud vol I would possibly keep the amp because it does take off that load from the Integra. But I don't do loud.
See my reply earlier. If I were you I would return the amp under Emo's return policy.
Modern amps sound identical when working within their design parameters, as your Integra is. You won’t hear any difference in 'sound quality' by using the Emo. The only time you need to change competent, well-designed amps is if your present amp is broken or if it cannot drive your speakers to the levels you need without clipping, or if your speakers present a very unusual or unstable load to the amp and the amp cannot cope with it (eg very low impedance). None of this applies to you which is why you cannot hear a difference.
The Emo amp sounds a little louder probably because the output gain on Emo amps is slightly higher than usual. You can easily get the same extra loudness by turning up the MV on your Integra!
- kbarnes701
- offline
Certainly can as +3dB is double the output power demand on the amp. But buggs1a listens at modest levels so he is unlikely to be clipping his 40.3. In fact if he can’t hear any difference between that and the Emo he definitely isn’t clipping it - he won't be clipping the Emo for sure.
I know you know this Theresa - just commenting generally. :)
- Theresa
- offline
- 2,291 Posts. Joined 11/2010
All true, sorry about the comment. My listening levels must be too loud as at one time I had 90 watt amps and clipped them regularly. Now, with an XPA-3 driving my mid-woofers it gets plenty loud. Of course having a dedicated amp for each driver (and active crossovers) also provides higher levels without clipping.
- kbarnes701
- offline
No need to apologise. Yes, I listen loud too and feel more comfortable knowing I have a lot of power in reserve. All my speakers are 4 ohm models too so the current draw from the amps is higher.
Buggs1a's experience is typical of many who swap amps unnecessarily I'm afraid. At least he had the good sense to realise that the sound is the same in his case. It is refreshing to read about someone who is honest with himself and remarkably immune to the placebo effect. How many times have we read, in similar circumstances, stuff like "the new amp revealed hidden detail in the mid-range with extra sparkle and clarity in the higher frequencies. Imaging is vastly improved too and the separation between instruments is palpable. The space between notes is inky black now. I am hearing things in all my CDs that I could not hear before. Even my wife noticed the difference." LOL!!!
- Theresa
- offline
- buggs1a
- offline
- 1,052 Posts. Joined 2/2003
It is true that I can't hear a quality difference audibly. True. And I will return it. I'm disappointed.
I'm going to try the Marantz SR7007 today. Good thing is it has a feature I would like anyway sorry.
And I am truly honest. If I don't notice a difference I'm not sure there's anything that will make me think something different.
- Theresa
- offline
I don't want to get into the all amps sound the same discussion but I have heard differences between a few receivers in the past even though slight.
I would not say all receiver's sound the same. Amps do sound the same for the most part.
- kbarnes701
- offline
Oh you can hear differences between receivers - they can use all manner of sound processing, DSPs, tone control, equalisers etc. It's amps where, within the limitations I mentioned, you won’t hear any differences.
Yes, it must be frustrating. What was it that drove you to try an external amp in the first place? What deficiencies in your current system were you trying to overcome?
What is it you expect the Marantz to do for you that the 40.3 doesn't do? Sound-wise I mean? It may have features you want of course that the Integra doesn’t have.
- kbarnes701
- offline
I imagine it is because they are looking for something that doesn't exist: audible differences between modern amps working within their design parameters.
Or, possibly, they have some deficiency in the sound their system produces and they mistakenly believe a new amp will overcome the deficiency and improve the SQ. Chances are, of course, that if the SQ is not as desired, then the room or the speakers is the culprit, so changing amps but leaving the latter as they are can't help.
As we (you and I) have said many times, a relatively small investment in room treatments is likely to make substantial differences to the SQ. Failing that, some decent electronic room EQ. And of course, getting better speakers and/or subs is always worthwhile. But electronics - pah! The differences between them are either non-existent or minuscule and inaudible.
Time to walk my dog now - it's -5 degres here.
- Theresa
- offline
don't be disappointed though...loving and lost is better than not loving at all....basically now you know and dont have to play the what-if game....and in the grand scheme of things only cost you a very small amount of money to try it. I WOULD recommend trying just a few more source material at higher levels just to see if you really dont need it before lugging that monster to the PO
- buggs1a
- offline
When I had the marantz sr7005 I liked the sound. It was unique. I know it was different then anything I heard before. I dont know how to describe it. I did not keep it because I had to manually change the sound output sometimes even though it was set for last used. I'm hoping for the same or better sound from the sr7007. If I try the 7007 I may or may not notice anything. If not back it goes.
My speakers are M&K lcr750 thx mk2 for the 3 front. The matching surr55t tripole for surround with SVS pc12 plus with 525 watt amp.
I am hoping for an improvement to tide me over till I get better speakers. However I'm thinking speakers will cost over $8k to be good enough. Kinda like the McIntosh XR100.
I get bored easy with home theater.
- bfreedma
- offline
- 1,950 Posts. Joined 10/2005
Then everything is operating correctly. I have an XPA-5 and have the exact same experience, which was what I was expecting. There may be marginal improvement over the internal amps in my Denon A100 when I really get to higher volumes, but no change, subjectively or measured at any reasonable volume.
There is a lot of unreasonable expectations and subjective observations when it comes to amps and the XPA-5 is no different. The XPA-5 is a fine product, but it (or any other amp) won't break the rules of physics, so unless you have low efficiency speakers or a huge room, buy it because you want it, not because you need it.
- buggs1a
- offline
- kbarnes701
- offline
Sorry Theresa - I meant -5 centigrade - that's about 23 F so you are colder than we are ATM by quite a way.
- buggs1a
- offline
- buggs1a
- offline
Would this system be good specially compared to my M&K?
http://www.martinlogan.com/electromotion/index.php
- DonH50
- offline
- 4,293 Posts. Joined 2/2010
- kbarnes701
- offline
- markrubin
- Trader Feedback: +7
- Volunteer Moderator
- offline
- 21,872 Posts. Joined 5/2001
- deltadube
- offline
- 1,008 Posts. Joined 11/2012
All true, sorry about the comment. My listening levels must be too loud as at one time I had 90 watt amps and clipped them regularly. Now, with an XPA-3 driving my mid-woofers it gets plenty loud. Of course having a dedicated amp for each driver (and active crossovers) alsoc provides higher levels without clipping.
clipping is really bad stuff for the speakers so with more power you eliminate this danger...
im disappointed to hear that there is no sound quality improvements tho... under the product descriptions at emotiva for the amps they do clearly mention improvements...?
i do like it loud sometimes and my denon 3313 just dont have enough power at 125 wpc to take me up to reference levels.. starts to clip.. i set my limiter to -10 db sounds great there
but sometimes with a good tune you want a bit more eh..
cheers
- deltadube
- offline
is that -5 c or -5 f
im plus 1 c today in Canada.... i got to get me some more power...
so you think those product description of the amp at emotiva are misleading? sonic nirvana!
- Theresa
- offline
Yes, sonic nirvana
Marketing is often misleading (or outright lies). Cold here today but tomorrow it's forecast to be in the '30s f.
Edited by runnin' - 1/17/13 at 1:31pm
- deltadube
- offline
wow just step out to get the mail cold front came early... -10 C now.... thats the coldest its been this yr... global warming does have a few benefits around here... usually we get some -30sC stuff
this time of yr but its been about 8 yrs now... and summers way to hot.. need to move farther North.. like the dinosaures did...
- kbarnes701
- offline
-9F equals -22.77777777777778 C
check it yourself:
http://www.wbuf.noaa.gov/tempfc.htm
:) My bad - I was looking at +9F - +9F is 13C. My apologies to Don and thanks to you for the correction. It's decades since we used Fahrenheit in Europe - not that that's an excuse!
- Official Emotiva XPA-5 Owners Thread
Recent Discussions
- › AVS Can't-Wait Special—"Mastered in 4K" Blu-Ray Releases 19 seconds ago
- › Sony KDL R450A 20 seconds ago
- › 2013: If Sony does move to LG panels, is it possibly the end of... 24 seconds ago
- › The Official ChromaPure thread 24 seconds ago
- › Official Sharp AQUOS LC-70LE757U, LC-80LE757U and LC-60LE757U... 36 seconds ago
- › Microsoft fires the first shot in the "NEXT" generation.... 48 seconds ago
- › Official Samsung UNxxF8000 Owners Thread 1 minute ago
- › 2013 Panasonic Settings/Issues Thread 2 minutes ago
- › Guide To Building A Media Storage Server 2 minutes ago
- › Townhouse party wall having triple leaf effect 2 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
