Sorry I wasn't more specific.
Featured Stories
Topics Discussed
Related Forum Threads
- Marantz AV7005 Last post on 5/18/13 at 12:45pm in Audio Gear
- Emotiva XPA-5 Last post on 5/23/13 at 11:57am in Audio Gear
- Emotiva amp connected to my Yamaha AVR, would this help any? Last post on Today at 2:08 pm in Receivers, Amps, and Processors
- Need a 5ch Amplifier - Parasound Halo A52, Emotiva XPA-5, or something else? Last post on 4/15/13 at 3:57am in Receivers, Amps, and Processors
- Emotiva XPA-5 Last post on 4/14/13 at 8:03am in Audio Gear
Related Reviews
Official Emotiva XPA-5 Owners Thread - Page 29
Gear mentioned in this thread:
no worries....I just didnt read your commnet correctly the first time....half distracted by the work I am supposed to be doing and cruising avs at the same time.
- kbarnes701
- Trader Feedback: 0
- offline
- 10,437 Posts. Joined 1/2008
- Select All Posts By This User
i do not think bi wiring has no purpose especially if you have higher gauge wire.. by bi wiring you would be lowering the resitance of the wire...
cheers
No, you won't. Biwiring could only make a difference if the original single wiring was ridiculously thin for the job. Assuming any decent speaker wire (say 12 AWG or better) then biwiring is pointless. The reason is physics again - google 'superposition theorem' and it will explain why I am right and you aren't on this occasion.
- Theresa
- offline
- 2,291 Posts. Joined 11/2010
Speakers have four binding posts because some of those who consider themselves audiophiles think that biwiring/passive biamping will make a difference. Its a sales gimick.
- deltadube
- online
- 1,038 Posts. Joined 11/2012
cheers
can you make 18 awg into 12 awg?
- deltadube
- online
better sound i swear ...
denon say it will stop the electromotive force from effecting the tweeter!
maybe you can explain electromotive force from the woofers effecting the tweeter...?
electromotive force sounds so cool..
does denon have an R and D department or just marketing..? i dont even see adds for denon...
cheers
- deltadube
- online
- Theresa
- offline
- deltadube
- online
Not sure about that, but you can touch base with Emotiva directly and ask for reconditioned amps. They usually have them available at a discounted price, free shipping to your door and full 5 year warranty.
If you want to save few more Dollars, then second hand units are always available at multiple forums. Only thing to consider is to buy from someone with positive references/feedback that you can check (ebay, Audiogon, etc.) and also, make sure the unit is still under warranty and the person has that unit registered at Emotiva under his/her name. Hence ready to transfer the warranty over you.
Emotiva tracks warranties by the name of the original buyer or subsequent buyers. Important - Serial Number doesn't work for them. So, be careful about it.
Good luck!
- kbarnes701
- offline
cheers
I don't understand the purpose of the question, sorry...
If you mean if someone is using 18 AWG and they then biwire, will that have a benefit? Yes it might. I did say that if the original wiring is totally inadequate then using twin wires coud make a difference. But you don;t need to biwire for that - just replace the inadequate wire with 12 AWG.
Did you google superposition theorem?
- kbarnes701
- offline
cheers
The electromotive force argument is spurious. The argument is that biwiring eliminates the backwave EMF. But the reality is that the cables are wired in parallel to one amplifier, so they just electrically combine at the amp. Denon can't change the laws of Physics, not in their R&D department and definitely not in their Marketing department! ;)
All that is good, but you missed one point...............There are no laws at the Marketing Department...........
Sorry, I just can't resist on that one!
- deltadube
- online
cheers
argument who me.. i was just asking a question.. .. argu with Denon. they wrote it electromotive force from the woofers effects the tweeters..
cheers..
- deltadube
- online
Good luck!
always have trouble buying used.. i like the bling of brand new eh..
wish they did deliever free to my door in Canada.. im not that far eh.. i should plan a road trip in the summer go for an amp and subs from the usa.. the shipping charges i save would pay for the gas..
cheers..
- deltadube
- online
cheers
Hey K Barnes.. just thought i would you let you know ... i took off the bi amp feature from my denon and disconected the extra cables...
had a listen to the same music.. well i cant tell a difference really.. but i can hear my center channel better now..
i swear i thought it was better but in reverse i cant really tell...
cheers
- deltadube
- online
- kbarnes701
- offline
cheers
cheers
Well done, dude! This is the first step to understanding the things that make a difference to SQ (room and speakers), the things that make very little, if any, difference (amps and electronics) and the things that make no difference whatsoever (magic cables, biwiring etc).
- kbarnes701
- offline
No - you will be fine. More power is better for your speakers than too little power. In a balanced and calibrated system, all the channels will be level-matched anyway.
- Theresa
- offline
- Theresa
- offline
- deltadube
- online
How much more power is reasonable ... over the speaker rating... in your opinion?
so we can add amps after all? if a bit more volume is disired...
i just order up a whole bunch of dry wall today.. for my room ht listening room..
rough size is 20 x 12.5 x 7 one door and 1 small window only..
cheers..
- deltadube
- online
more power more clean volume before clipping.. great room size you have...
what are your speakers rms ratings..
could use another sub with that size room..
cheers..
I would exercise a little bit of caution here. In a thread on the Emotiva forum, several members are reporting sibilance with the XPA-5 when playing some music.
Just a thought, but you might want to read and decide if you would be at risk for this.
Sibilance can usually be eliminated.
1. Get better speakers. I believe that Paradigms were reported to be sibilant with Emo by one poster. See #3.
2. Get a processor/pre pro or AVR that does not promote sibilance.
3. Get a Parasound amp. They have been reported to to eliminate sibilance. If they in fact do this they are defective or of poor design.
Edit: on post 17 on page one, an owner says that even though he changed his speakers, he still has sibilance, though it's more subtle now.
Edited by runnin' - 2/3/13 at 5:25pm
So are you suggesting buying an XPA-5 and then replacing one's speakers? That doesn't make a lot of sense. Usually one decides if a given amp would be a good fit for their existing system. And the thread indicates that several brands of speakers are involved. Any other suggestions?
Speakers and room acoustics and processors have the biggest impact on SQ IMO. Unless one feels that he has to have his amp as a center piece of conversation as opposed to SQ he gives little thought to the brand. Of course the kool aid is free flowing for trolls on the Emotiva forum.
- Official Emotiva XPA-5 Owners Thread
Recent Discussions
- › Dayton RSS390HO-4 Flat Pack Build 19 seconds ago
- › Pros and cons of refubs 2 minutes ago
- › plasma....it's just not that good. I'm not trolling! 3 minutes ago
- › Bracket extension? 4 minutes ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 5 minutes ago
- › Star Trek: Into Darkness in Dolby Atmos 5 minutes ago
- › LG PASSIVE LM6200 dedicated thread... 7 minutes ago
- › Samsung 'SlimFit' CRT keeps shifting from bright to dark.... 7 minutes ago
- › Optoma GT750 lamp exploded 8 minutes ago
- › Dali speakers 8 minutes ago
Recent Reviews
- › Marantz AV8801 by zuluwalker
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
