After reading through a good deal of these threads and getting some good ideas if I were to do it again, I just wanted to share my "man cave" with you all in hopes that at the least it could give others some ideas or "ah hah" moments.
The room consists of a pool table area, theater area, and bar; completely unique right?
Here's how it started, new home with an unfinished basement.
This is the view from standing in the pool table area, looking first into the theater area (middle) where the tv (sorry, no screen) will be placed in the niche on the right side, then on the far end of the room, the bar. The small room to the left is the sump pump room, which will be disguised as a wine cellar:
Still in the pool table area, looking at the theater niche:
In the bar looking the other way to the pool table area:
Here's how it started, new home with an unfinished basement.This is the view from standing in the pool table area, looking first into the theater area (middle) where the tv (sorry, no screen) will be placed in the niche on the right side, then on the far end of the room, the bar. The small room to the left is the sump pump room, which will be disguised as a wine cellar:
The tv is viewable from both ends, the niche won't be the greatest for front speaker placement (still have not done that), but it's a compromise I had to make for an "overall" room. I was trying like crazy to fit a 9' table, but that would have meant no theater.
Tough choice, but that's where it had to go. The other surround is wired to the other side of the hallway (actually in the billiard area). So now I bet you're wondering what the heck I'm using - yes, in-walls.
I was really set on in-walls that have back-boxes but honestly, for the price of some cheap brand names without back boxes, I will try them first. Please don't kill me.
