Originally Posted by mikek
1st issue: Sharpness at zero: this turns off any TV produced "artificial" sharpening.
2nd: I think that was discussed a dozen or so pages back.
3rd: I have seen that. I believe that if you turn off the eco setting to off. I think that what causes the complete black screen.
-mk
-mk
Thanks mikek for your replay.
Regarding the Sharpness I must admit that my two previous plasmas had the sharpness default option (depending on the Picture Option) around or near the middle of the ruler, which appeared sound to me. The Samsung’s User Manual is no help in this issue. Nevertheless I find the image too soft for my taste near Zero, so I will keep my settings (about 30 for the Bluray and 40 for the DVD).
Respect the HDMI Black Level control, the only thing I found specifically on the thread was a comment by tomsem that depending if the output was on RGB or YCbCr this function is respectively available or not . I am no able to tell if my LG DVD is outputting in RGB, because the only option it has in this regard is something they call BLE (Black Level Expansion); but also the Sony Bluray has something “similar” they call HDMI Deep Color Output. As usual the User Manuals on both units are cryptic about exactly how each one works or what actually does. By the way, which is supposedly the best way to output to the TV RGB or YCbCr?
I have checked the Eco function and it is completely turned off, so I will stick to the school of thinking that it is something that is inherent to the design of the processing engine of the TV.
. As long as the TV is under the warranty period i'm going to have them fix any issues. I have a service ticket out but the repair company and Samsung are arguing about who should foot the bill for the repair. May be a few weeks before it's fixed. Hopefully Samsung foots the bill as the repair people are a local company.
