Originally Posted by scoobdude
PCD: some movies are filmed in a 2.35:1 aspect ratio. Nothing you can do about it. Might be able to zoom in. But important thing to watch is the resolution. If it states its at 1920 by 1080 then you are getting full resolution. Do you have any other BDs to test?
On to the 24Hz thing. The output from the player is 24 and that is what the TV is receiving, but it is not what the TV is putting out. It converts it to a 3:2 pull down.
Hope that helps and someone please correct me if I was wrong here.
Although Scoobdude is correct about the C550's handling of 24Hz input signals... But, you mentioned that you have a G1, it could be different.
Originally Posted by PCD
EDIT: I should mention a few other strange things....I have PIP mode available....also, as soon as I did the Blu Ray it said 24FPS on screen which I found intersting....I thought you had to turn the 550 into a 590 to enable that stuff...my actual model number is PN50 PL C550G1
With the above reaction to the 24Hz signal, you might indeed have Cinema Smooth (CS) active on your set.
, and the built in speakers cover the rest for now.
