AVS › AVS Forum › 3D Central › 3D Displays › Update: Mits 3DC-1000 3D Converter Box Will NOT Work on Samsung DLPs!
Update: Mits 3DC-1000 3D Converter Box Will NOT Work on Samsung DLPs! - Page 12
post #331 of 338
Originally Posted by EmerJency View Post
It may be my only option, short of buying a new Mits or next gen 3D plasma/lcd.
EJ
You could see if any forum members would be willing to program a Gefen for you for free if you sent it to them.
post #332 of 338
Originally Posted by mikemav View Post
If anyone here gets the Mits adapter (hopefully it's returnable where you order it), and would like to send it to me to test it out, I'm in a prime position to tell for sure. I have both the Mits and a Samsung P450 plasma, as well as the EDID device, so I could try with and without spoofing the Mits EDID. I'm in Northern VA/Wash. DC area if anyone is local. I will probably eventually order the Mits adapter (not the full kit w/ glasses as I have Nvidia's already)- I just have not been pressed to do it yet as there isn't much content outside of the PC games I already use on the Mits in 3D.
Isn't the Samsung P450 Plasma 720P, or only accepts a 3D signal at some proprietary resolution? If so the Mits converter won't work with that set regardless of EDID, it only outputs 1080P/60 for 3D.
post #333 of 338
Originally Posted by steelers1 View Post
thats the mitts adaptor with out the glasses. it comes with a hdmi edid tool.
I've just recently heard about the Mitsubishi adapter and this new standardized 3d in general as a possibility on my Samsung DLP (HL61A750). If I'm understanding this thread correctly, these are the facts as it pertains to my Samsung TV:
* Recent Samsung 3d DLPs won't natively work with the DirecTV 3d output format and other newer devices that use this format
* Mitsubishi makes an adapter but is locking out Samsung displays even though their TV technology is likely about the same inside (3D DLP from Texas Instruments) because they just feel like it or the adapter is subsidized or something
* The link above is that adapter + another adapter inline to HDMI to spoof a Mitsubishi EDID
* The Geffen HDMI Detective may be able to work inline to fix this issue but no one has this + the 3DC-1000 to test it
So is it the Geffen HDMI Detective that's included with the Tru3d 'kit' or are we unsure of this? Specs on both say 5v DC power supply. I'm trying to determine if that kit costs a lot more than buying things separately and somehow getting the Mitsu EDID on the Geffen box manually.
post #334 of 338
The tru3D kit has their own HDMI EDID unit it does not include the Gefen detective unit see:
http://www.tru3d.com/products/view_p...D%20DLP%20HDTV
post #335 of 338
I've read that whole page a few times and I'm not seeing them say any specifics about the EDID tool that's included other than it's pre-programmed with a Mitusbishi EDID but can be reprogrammed.
post #336 of 338
Following is from the specifications section of the link I provided
VESA Emitter 3 pin jack: 1
3D Mode Input Compatiblity
Full HD 1080 (per HDMI) (Blu-ray): 1920 x 2205 24Hz
Full HD 720 (per HDMI) (Blu-ray): 1280 x 1470 60Hz
Top/Bottom 1080p 24Hz: 1920 x 1080
Top/Bottom 1080p 30Hz: 1920 x 1080
Top/Bottom 1080p 60Hz: 1920 x 1080
Top/Bottom 1080i 60Hz: 1920 x 1080
Top/Bottom 720p 60Hz: 1280 x 720
Side-by-Side 1080p 24Hz: 1920 x 1080
Side-by-Side 1080p 30Hz: 1920 x 1080
Side-by-Side 1080p 60Hz: 1920 x 1080
Side-by-Side 1080i 60Hz: 1920 x 1080
Side-by-Side 720p 60Hz: 1280 x 720
3D Sgnal Output
Checkerboard 3D 1080p 60Hz
Checkerboard 3D 1080p 60Hz Signal Pass Through Compatiblity
Video Siganls 2D Pass Through Output
1080p 24Hz/30Hz/60Hz
1080i 60Hz
720p 60Hz
480p 60Hz
480i 60Hz
PC Signals
Checkeboard 3D 1920 x 1080 60Hz
1280 x 1024 60Hz
1360 x 768 60Hz
1024 x 768 60Hz
800 x 600 60Hz
post #337 of 338
But they also state:
This Samsung 3D DLP Adapter KIT includes the necessary pieces pre-programmed and READY TO USE with your Samsung 3D DLP HDTV for 3D TV, 3D Blu-Ray, PS3 and more!
To Use the Mitsubishi 3DA-1 Adapter and HDMI Tool Simply Following These Steps:
* Power Off ALL of your Devices.
* Connect 3D Ready Video Source HDMI Output (cable-box, PS3, etc) to the Mitsubishi 3DA-1 Adapter HDMI Input.
* Connect the Mitsubishi 3DA-1 Adapter HDMI Output to the HDMI Tool HDMI Input
* Connect the HDMI Tool HDMI Output to the Samsung 3D DLP HDTV HDMI Input.
o NOTE: Consult your Samsung 3D DLP HDTV manual for 3D mode settings. It is recommended that you connect your 3D source to input on the back of your samsung 3D DLP to the Input labelled HDMI/DVI or HDMI/PC. This is usually HDMI Input 3.
* Power on all of your devices.
* Use your Samsung 3D DLP HDTV remote control to activate 3D Mode on your Samsung 3D DLP HDTV.
* Turn on your 3D Video source.
o NOTE: This KIT does NOT convert 2D to 3D. You must have a 3D video source to view 3D content using this kit such as 3D Pay-Per-View, 3D Live Sports, 3D Blu-Ray or other 3D Ready playback devices.
!!WARNING!!
* Do not clear the memory presets that are stored on the HDMI Tool. If you clear the memory presets, then you will have to follow the directions below.
To Re-program the HDMI Tool:
And then the go on to show how to reprogram the device if you accidentally erase the Mits codes.
post #338 of 338
Tru3d updated the sdc-1000 to work on samsung dlp 3d and was only 194.95 it works with my ps3 i was playing pool in 3d on my ps3.
  Back to Forum: 3D Displays
