I think that subject covers it all. Hopefully I can get some straighforward answers.
I have an Onkyo SR605 receiver. It is capable of most formats of audio decoding. I would connect it via HDMI to a Blue Ray Player. I have some questions.
1. If I have the option on the player to output PCM or Bitstream, what do I choose? Which is best? I see on one player you can further choose Bitsream Reencode where it coverts the PCM output to DTS or Bitsream Audiophile where it only outputs the main audio soundtrack and the receiver then does the conversion whereas on the PCM the player decodes primary and secondary to PCM audio. I am way confused on this one. Seems to me to go with Audiophile, but at the same time that one ignores any secondary audio tracks. Help?
2. What is Divx (R) and why would I have to register a player to use it? I know, not audio related, but I know someone can explain this.
3. In my receiver manual there is a chart. It shows all the listening modes available based on the source format. Then it shows like Multichannel and stuff like */2 and except */2, 2ch and 1/0, 1+1. What the heck is that all about? I get the idea that say if you have a True HD source, then the reciever can support stereo and True HD. For Dolby Digital Plus it can support a whole bunch others including PLII and Neo:6, etc. It all depends if you have a 5.1, 6.1 or 7.1 setup. I get that. But what's with all of the symbols?
Am I reading too much into this? My hearing is shot anyhow. ;-)
, lossless decoding produces the same PCM no matter where it is done. Decoding in the player and the receiver produce the exact same output.
