Originally Posted by
Shadow_7
I thought that the SDHC theoretical limit was 1TB. Not that you'll find any cams that support larger than 32GB.
Is this gear going to be unmanned or something? Lots of cams with dual SDHC slots that allow hot swapping for continuous type recording across several cards. I'm not sure how that works, but I remember it being a selling point for DUAL SDHC.
Sorry, do u mean that the cx/xr550 got a DUAL SDHC card slot ?
I mean I can use 2 cards in it ? Maybe 2 SDHC ?
What about SDXC. Is sony compatible with it ?
Also, can the xr/cx550 mount both the cards (SD card and Memory Stick PRO Duo card) at the same time ?
In that case, it could be possible to have at least 64gb mounting 2 x 32gb cards.....
Thank you
