AVS › AVS Forum › Audio › DIY Speakers and Subs › Dual Opposed AV15H Subwoofer Build
Dual Opposed AV15H Subwoofer Build - Page 6
post #151 of 801
Okay, so hooked up the subs outside the box using this diagram ...
http://a248.e.akamai.net/pix.crutchf..._4-ohm_2ch.jpg
Had this multimeter in my basement so tried to measure the OHM's ...
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Didn't have the manual for it, so all I did was connect the red to the V.OHM.mA bottom right connection (with the black in the middle), then set the dial to either the 6pm or 7pm mark (can't recall which, i.e. either the green 200 or green 2000). You can zoom in on that picture to see what I mean.
I'm getting 3.2 as a reading. Does this mean the drivers have a resistance of 3.2 OHMs instead of 4?
I'm using T90 12 AWG stranded wire for all the connections (if that makes a difference, seems stiffer than typical 12 gauge speaker wire?).
post #152 of 801
pbc,
Are yours actually DVC versions?
James
post #153 of 801
The spec for Re (or resistance that you can easily measure) is 2.7ohms, which is not uncommon for a "4ohm" driver. But your multimeter may or may not be accurate to better than 0.5ohm.
You measured DC resistance; actual impedance will vary widely over frequency. Other than short (zero) or open (infinite), I wouldn't worry much about it.
Edit: By the way, nice build!
post #154 of 801
Originally Posted by exojam View Post
pbc,
James
Yup...
post #155 of 801
Thanks...
post #156 of 801
Well, decided "what the heck", mounted the drivers onto both boxes, added about 2.5 lbs of fill in each box (felt like if I put more I'd really be stuffing it too densely) as well as screwing in the terminal cups and put them into their spots. Just awaiting for magnets so I can finish the front baffles and do the grills, and waiting for my XLR to RCA cables so I can hook them up to the amp (while praying that they actually work). Relatively heavy boxes, but still managable. I'm guessing about 100 to 115lbs each (assuming the drivers are 40 each IIRC?). Whomever invented "furniture sliders" should be praised, even on carpet they glide around like they're on ice...
post #157 of 801
I have to say, they turned out much better than I thought they would when I started (was scared they'd look like cr*p!). Yes, from 2 feet or so you can start to see some imperfections, but from 5 feet out they look pretty darn good IMO. Adding grills seems like a shame as I'm starting to like the aluminum drivers on the dark boxes.
Mind you, guess the grills will provide a tad of protection from the 3 year-old!
Hopefully the amp fan isn't too loud (but I know I'll end up modding it), and soon will pick up a DCX after some measurements without it in the system. Can't wait.
For now the SVS PB13 has been relegated back to its old position in the rear corner. Wonder if I should set up all 3 eventually vs selling my SVS ... Hmmm ...
post #158 of 801
.... oh, and yes, I need to slide the TV over a few inches now on the mount to centre everything a bit better now that I've gained a few inches with these subs being thinner than the PB13.
post #159 of 801
Very nice!
For your first build you got excellent results and those suckers are going to pound.
Can't wait to hear your impressions on how they sound.
post #160 of 801
Originally Posted by mjaudio View Post
Very nice!
It's how they sound that will determine the results though!
I can't wait either.
post #161 of 801
pbc, just wondering, how close are the rear drivers to the wall? I think that when you hear the AV15H's, you'll end up selling the PB13 sub. To integrate all of those subs is not going to be easy (if possible at all), since they are different, two sealed subs and one ported.
post #162 of 801
Right now about 2 to 3", but I'm going to push that out to about 4" max. Was going to try and integrate the PB13 in sealed mode, but yeah, if these puppies sound as good as everyone says they do and hit deep I likely won't bother. Just curious as to what a 3rd sub will sound like in the small room. Nice thing about the PB13's is that they are still worth quite a bit on the use market (for a reason obviously!).
An individual wants to really compare his Sub 25 to the PB13 so I'll see how soon I sell it. I think my bro wants a 2nd sub as well, he has a PB12Ultra and is considering adding a PB13, not sure how well they will match though.
post #163 of 801
Darn, removed the fan from my QSX RMX 5050, and now can't recall how it goes back in (i.e., which side the front faces). If I recall, airflow is pulled in from the front and pushed out the back?
post #164 of 801
From the QSC page on that amp.
Continuously variable-speed fan, rear-to-front air flow.
http://www.qscaudio.com/products/amps/rmx/rmx5050.htm
James
post #165 of 801
I was wondering the same thing.
post #166 of 801
They will be about 3 to 4" from the wall to the outer edge of the cabinet plus another 1.5" (as I an outer baffle which adds 3/4" and then another 3/4" for the grill insert/lip that I've incorporated into the design).
post #167 of 801
not sure if it has been discussed, but the av15's are low q drivers with a -3db point up around 60hz or so. with an 80hz cross and no eq, they may sound like they lack depth. the dcx2496 has a 12db/octave shelf filter which will more or less match the rolloff of the sealed enclosures in the same way as a linkwitz transform (which is what you would use the bassis for). however, if you have a really small room, you may get lucky and have a high enough pressure vessel gain point to not need the shelf filter, but that would be rare.
i'd also call monoprice and ask if your order got screwed up and what the eta is. maybe it is a canada issue. stuff that i have ordered from them arrived within a couple days.
the minimum dc resistance reading will always be less than the impedance, so your reading seams fine. as was stated, impedance will vary with frequency response, because every subwoofer has some sort of impedance peak in the bass.
edit, you can also test your subwoofer wiring by applying a 9 volt battery to them. 9 volts into 4 ohms is about 20 watts, so is a very safe test level. if you wired everything up properly, when you attached the positive to positive and negative to negative, the cones should move out when the battery is applied.
post #168 of 801
Is this only in a sealed design? I thought John posted measurements of the AV15s running very well even past 500Hz.
Im curious because I have seen them used as bass bins (I believe Salk does this). THere are also some recent new projects assuming the AV15 runs up to maybe 200Hz.
Maybe thats for the AV15H and not the AV15X?
post #169 of 801
Penn,
I think LT maybe saying that below say 30HZ (just using 30 as a random number) the AV will not have a lot of power, umph, however you want to describe it. This is just the way I am reading it since he mentions the -3 being around 60, I figured he meant once you start to go down past that you will be losing stuff. I could be wrong and I am sure LT will see these and correct as needed.
James
post #170 of 801
I wish this myth would go away because it's simply bad advice. The AV drivers in that box will show a very wide F6 BW, not anything resembling a .707 second order roll off and the F3 will not be at 60Hz. So, a 2nd order shelf is a stab in the dark at best and is asking the amplifiers for X16 the power across most of the subs operating range, and no other options.
The Marchand Bassis is still the hands-down best tool for shaping in-room response, extension and F6 BW. Short of that, more than a shelf filter is required and +12dB is not recommended in most cases of a 4X15" system powered by a QSC 5050 in 2500 cubes.
Bosso
post #171 of 801
Bosso - so are my WINISD measurements on page 1 incorrect, or simply "Theoretical and not what will actually be seen in room"? I.e., from those measurements it seems to corroborate LTD's hypothesis that the AV15's have a -3db around 60hz or so. It also calculates a Q of 0.662?
I think what I'm going to do is measure the response in-room as is, before purchasing the Bassis or DCX. Not sure if that will help identify what would help best?
Got my cables in from Monoprice finally, and my magnets as well. So will hopefully get to testing this weekend.
BTW, I was reading Ricci's write up on how to set the level of identical dual subs (mainly the point about putting htem in the middle of the room to level set each to the same level then putting them in their spots and using the AVR to set final levels to reference).
Curious, given one will be in a corner (with a back and side wall boundary helping it) while the other will only have a back wall (as it will be next to an open doorway), wouldn't it necessitate that the amp puts out more gain to that woofer vs the one in the corner? Have never setup duals before, so go easy on me!!
post #172 of 801
It hasn't been my experience with the AV15H that the F3 in your box will be 60Hz anechoic. JJ posted a FR somewhere early on and I lifted it. I then laid it over my close mic measurement of the Raven, a dual driver sealed enclosure just a bit smaller than yours.
If I find it I'll post it here, but the F3 was in the low 40sHz, IIRC. JJ's was even lower, but I don't know the specifics of his measurement.
I'll say it again; for multiple subs, I like the features available on the DCX, for mating sub performance to the room, Bassis, all day long. Best to have both.
If you're set on one or the other and not both, I agree that I would get close mic and LP mic traces and look at what the room is offering, then decide.
Should be lots of fun. I'll be following along.
I disagree with the method. I see no reason to pull the subs to a different distance from the mic and in-room response for calibration. I would set the levels from the LP to where they'll sit (your placement is virtually equidistant) and set the AVR/amp levels for best stab at unity gain.
All the more reason to set levels in place.
Bosso
post #173 of 801
So I'm lifting my 70lb monster of an amp upstairs, which of course wouldn't fit into my Salamander stand with the doors on due to the friggin ears, so am unscrewing the door. I look over and see my son, who's 3 and in potty training, standing at one of my subs with his leg up.
Yes, sure enough, he's peeing on my subwoofer. PEEING ON MY SUBWOOFER! He looks at me, sees my face, and just says "Sorry Dad", in that voice which of course makes anything he does "okay". I asked "but why'd you have to pee on my new subwoofer", his only response was "I don't know. Sorry Dad."
Yes, completely off topic, but possibly a first in DIY Subwoofer history?
post #174 of 801
Grrr, so it looks like I need to remove the top of my Triple 20 rack to put the darn doors back on, what a pain. Will get back to this tomorrow or Saturday.
post #175 of 801
Man, your son is a tough critic
post #176 of 801
Just so you know, that post just made my night....I cant stop laughing picturing that happening...that and I know that someday that will be me.... lol
post #177 of 801
Yeah, wait til JJ reads this. Clearly he has some work to do on those AV15's!
post #178 of 801
john j. (aka stryke) mentions av15h has f3 of 67hz or so in another guys small sealed build. the confusion here is just the point of measurement. when i mentioned 60hz, i was talking about without a low pass filter. with an 80hz low pass filter, the peak is at 60hz or so and the -3db point moves down to around 36hz. also, the 12db per octave is a pretty good guess for a small sealed enclosure, until pressure vessel gain kicks in (and remember that is just the shape of the contour, not how much you have to apply, you may only need a few db, if any in a small room, which is why i hedged my comment the way that i did.)
http://www.aespeakers.com/phpbb2/vie...php?f=1&t=1749
bosso, what does a bassis do that a dcx cannot?
from an old post on htguide:
"The LT can be replicated as the sum of 3 filters - two band (bell shaped) filters and one 12dB/octave shelving filter. The first band filter changes the Q of the box/driver to 0.7 at it's Fb. The shelving filter changes the response to Q=0.7 at the new desired Fb. The second band filter sets the Q to whatever you want it to be, e.g. Q=0.5, at the new Fb.
In practice, you may not even need the band filters. Just use a shelving filter to boost the lows. If the final response curve looks the way you want it to, it doesn't matter how you get there or what kind of fancy name you give it. It's all just EQing the bass response to be the way you want it."
http://www.htguide.com/forum/archive...p4/t-9744.html
post #179 of 801
I may even cross it over at 100 or 120hz, given everyone has said how capable these subs are in the upper regions and the fact that both subs will be up front with my S2 bookshelves on top so localization may not be a huge issue. Would that increase the F3 point?
I too am curious about what the Bassis can do that the DCX can not!
post #180 of 801
Def you should cross those over high, heck maybe even higher for that matter with your layout - you have the perfect scenario for it - you won't have any issues with localization - the subs will basically attach themselves to the speakers.....
By the way - nice to see your boy approves of your subs.... That was pee in the pants funny.... or at least it should have been...
