AVS › AVS Forum › Audio › DIY Speakers and Subs › Add sub woofer bass level control
post #1 of 3
Hi Everyone,
I'm kind of new to audio and I was wondering if anyone might have any advice for this little problem of mine...
My bass is excruciatingly loud. My sub woofer has limited level control capabilities. I was hoping to add a pot to adjust the bass.
Can I add this in between the two leads that connect the long-throw sub woofer to the PCB? Any suggestions as to what kind of variable resistor pot I should be purchasing? I've been reading that some types are better than others for audio.
Thanks for any help!
post #2 of 3
A detailed gear list is necessary to make any diagnosis. We can't tell you what the problem might be if we don't know what you've got.
post #3 of 3
It's a very lightweight 3pc setup I have for my bedroom. I'm just using some nice desktop computer speakers that give me agreeable sound.
Model is Altec Lansing VS4221
Sound Pressure Level (SPL): 98 dB
Total Continuous Power: 35 Watts RMS
Subwoofer: 19 Watts @ 8 ohms
@ 10% THD @ 40 - 160 Hz
Single Channel Loaded
System Response: 40 Hz - 20 kHz (-10 dB)
Signal to Noise Ratio
@ 1 kHz input: > 80 dB
Drivers (per satellite): Two 28mm full-range and
one 3" mid-bass driver
Subwoofer: One 6.5" long-throw woofer
Here's a PCB layout...but it's not quite in English.The two leads in-between the 3300uF/35V capacitor connect to the sub woofer.
