Originally Posted by
csun213
Thanks Dan for the response. Just wondering if the 630 and 650 are basically the same TV, why the 630 would have an extra input.
If the 30,000 contrast ratio is not a big difference then I will probably purchase the 630 and save a couple of $ however the prices between the 630 and 650 seems very close now.
I agree with Dan.
Samsungs documentation, website and printed material isnt
very accurate and we can only hope more care is taken with
the technical and assembly side.
There is a 6 or 7 pound difference with the 55C610/630 and the
55C650 but this may not be correct as Samsung copies a lot of
their documentation from previous years and in some cases do not
make corrections so the weight may not be accurate.
My 46C650 does have 2 component inputs so I assume all
units in the C650 series are the same.
I believe the 55C650 and the 55C630 are clear panels.
This is a clip from Samsungs brochures.
Reading this, one could assume those units are equipped
only with HDMI,USB and PC inputs.
CONNECTIONS C650
4 HdMI® (High-definition Multimedia Interface):
3 back, 1 side
HDMI® makes it easy to connect your home
theater with one cable per component.
Anynet+ (HdMI-CEC): Allows peripheral
AV devices such as a DVD player to be controlled
by a Samsung TV remote control.
2 USB: 2 side
1 PC input: 1 back
CONNECTIONS C630
3 back, 1 side
2 USB: 2 side
1 PC input: 1 back
