Originally Posted by kiwirabbit
We just bought a 55" Samsung LN55C630 and from day 1 it has had this weird problem with the left side. There is a brighter look to the left side of the TV. It starts from the edge and goes about 1/3 of the way into the tv. It makes any blacks look bluish grey, and its noticeable even if you are playing a full screen movie.
Do we have to just deal with this or do we try to get an exchange? We bought it from Leons and after a huge hassle with them about something else I'm not looking forward to dealing with them again about this.
It won't let me post a picture but here is a picture someone posted that shows what I'm talking about:
http://www.avsforum.com/avs-vb/attac...hmentid=182490
Ours is only on the left side though.
Wow, I had this exact same problem on my first 55" c650. Sent it back for a replacement...... and the 2nd one had the exact same issue! Both sets had this brightness problem on the right side though, not the left, and the thickness of that light band was around the same as in that attached picture you posted.
And note that I'm a big Samsung fan - we have a lot of their stuff in our house. I went with the c650 because we have an older LN40A550 which we liked a lot.
I tried really hard to like the c650 and tried twice... but both TV's had serious uniformity issues and light bleeding from the corners (in addition to that bright vertical band on the right side). Also, the 2nd set had seriously bad motion blur that was somewhat addressed with the AMP turned on, but I absolutely hated the soap-opera effect, so it was a no-win situation. Both panels were AA02.
I finally went with the Vizio XVT553SV (CNET's pick for best LCD of the year) and am finally completely satisfied. Even my wife who is completely non-technical says that the picture on our Vizio is noticeably better than the Samsung's. We also don't see any of the blooming issues like some other's have.
Sorry Samsung, I tried!
I had massive motion blur problems with my 2nd 55" c650. That got sent back like the 1st one (which had less motion blur, but had other issues).
And yes, you can get better for an LCD. My Vizio XVT553SV has no noticeable blur, even with their "motion smoothness" setting turned completely off. Like you, I also thought this blur was "normal" (especially on a larger 55" screen), until I saw the Vizio for myself.
