Code:
DISC INFO:
Disc Title: NEVERENDINGSTORY
Disc Size: 22,394,191,808 bytes
Protection: AACS
BD-Java: No
BDInfo: 0.5.3
PLAYLIST REPORT:
Length: 1:33:56 (h:m:s)
Total Bitrate: 31.67 Mbps
VIDEO:
Codec Bitrate Description
VC-1 Video 27911 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Codec Language Bitrate Description
DTS Audio English 1509 kbps 5.1 / 48 kHz / 1509 kbps / 16-bit
Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics Dutch 22.840 kbps
FILES:
Name Time In Length Size Total Bitrate
00003.M2TS 0:00:00.000 1:33:56.797 22,315,192,320 31,671
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:02:06.543 15,010 kbps 25,918 kbps 00:00:50.050 25,306 kbps 00:00:50.008 25,225 kbps 00:00:50.049 78,229 bytes 238,151 bytes 00:02:06.084
2 0:02:06.543 0:08:30.259 28,570 kbps 44,773 kbps 00:06:37.897 40,321 kbps 00:06:35.395 36,955 kbps 00:06:31.808 148,951 bytes 378,462 bytes 00:06:38.898
3 0:10:36.802 0:01:53.780 25,361 kbps 36,591 kbps 00:10:59.075 35,560 kbps 00:10:56.947 34,806 kbps 00:10:54.195 132,220 bytes 313,095 bytes 00:10:52.818
4 0:12:30.583 0:06:39.649 29,282 kbps 42,562 kbps 00:18:11.799 38,360 kbps 00:18:09.046 35,667 kbps 00:18:03.582 152,664 bytes 331,471 bytes 00:14:32.663
5 0:19:10.232 0:03:50.480 24,925 kbps 45,808 kbps 00:21:22.906 40,631 kbps 00:21:21.530 37,629 kbps 00:21:21.571 129,948 bytes 336,947 bytes 00:21:29.037
6 0:23:00.712 0:04:38.945 27,221 kbps 44,273 kbps 00:26:49.399 39,854 kbps 00:26:45.478 34,427 kbps 00:23:36.623 141,916 bytes 374,003 bytes 00:26:50.150
7 0:27:39.657 0:02:48.293 28,916 kbps 49,404 kbps 00:27:49.167 39,806 kbps 00:29:13.209 37,427 kbps 00:28:30.834 150,757 bytes 422,768 bytes 00:30:08.389
8 0:30:27.951 0:05:53.019 28,591 kbps 39,125 kbps 00:31:14.497 37,275 kbps 00:34:24.604 37,154 kbps 00:34:24.687 149,062 bytes 323,840 bytes 00:36:15.631
9 0:36:20.970 0:03:53.191 27,809 kbps 36,939 kbps 00:39:55.392 34,622 kbps 00:39:40.878 33,450 kbps 00:39:38.501 144,983 bytes 323,681 bytes 00:39:23.903
10 0:40:14.161 0:07:02.922 27,509 kbps 44,138 kbps 00:41:03.335 39,696 kbps 00:41:00.833 36,974 kbps 00:43:51.128 143,422 bytes 418,708 bytes 00:41:22.438
11 0:47:17.084 0:03:09.230 23,137 kbps 35,463 kbps 00:47:18.544 33,715 kbps 00:47:18.544 33,020 kbps 00:47:18.710 120,626 bytes 297,727 bytes 00:47:18.752
12 0:50:26.314 0:06:22.507 23,869 kbps 58,564 kbps 00:55:36.541 39,775 kbps 00:55:41.921 37,366 kbps 00:55:41.838 124,444 bytes 482,803 bytes 00:55:37.542
13 0:56:48.822 0:03:03.766 30,798 kbps 39,030 kbps 00:59:39.867 36,770 kbps 00:59:30.942 36,551 kbps 00:59:29.232 160,567 bytes 346,764 bytes 00:59:02.664
14 0:59:52.589 0:07:11.764 27,834 kbps 45,345 kbps 01:04:47.675 39,865 kbps 01:04:44.130 37,622 kbps 01:04:40.042 145,112 bytes 402,317 bytes 01:03:24.133
15 1:07:04.353 0:03:23.202 33,680 kbps 46,547 kbps 01:07:47.480 39,346 kbps 01:08:35.820 36,693 kbps 01:08:32.566 175,591 bytes 431,292 bytes 01:07:47.146
16 1:10:27.556 0:05:33.666 32,096 kbps 44,601 kbps 01:15:55.634 39,830 kbps 01:10:30.142 37,443 kbps 01:11:58.731 167,336 bytes 433,418 bytes 01:10:41.528
17 1:16:01.223 0:02:51.963 23,037 kbps 40,182 kbps 01:16:57.863 38,723 kbps 01:16:55.485 36,396 kbps 01:16:51.732 120,106 bytes 330,365 bytes 01:16:59.990
18 1:18:53.186 0:05:02.051 31,014 kbps 53,223 kbps 01:23:53.611 40,325 kbps 01:22:45.919 37,065 kbps 01:22:41.206 161,693 bytes 514,858 bytes 01:23:47.022
19 1:23:55.238 0:07:13.558 28,752 kbps 57,461 kbps 01:25:20.406 40,495 kbps 01:30:54.407 37,686 kbps 01:30:53.906 149,901 bytes 545,906 bytes 01:25:32.252
20 1:31:08.796 0:02:48.001 31,611 kbps 41,237 kbps 01:32:55.570 39,108 kbps 01:32:54.193 37,506 kbps 01:32:50.982 164,886 bytes 348,389 bytes 01:33:08.416
STREAM DIAGNOSTICS:
File PID Type Codec Language Seconds Bitrate Bytes Packets
00003.M2TS 4113 (0x1011) 0xEA VC-1 5636.714 27,911 19,665,903,231 106,961,211
00003.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 5636.714 640 450,931,200 2,642,175
00003.M2TS 4353 (0x1101) 0x82 DTS eng (English) 5636.714 1,509 1,063,215,244 6,341,244
00003.M2TS 4608 (0x1200) 0x90 PGS nld (Dutch) 5636.714 23 16,093,171 91,462
Code:
DISC INFO:
Disc Title: NEVERENDING_STORY
Disc Size: 19,479,987,916 bytes
Protection: AACS
BD-Java: No
BDInfo: 0.5.3
PLAYLIST REPORT:
Length: 1:34:04 (h:m:s)
Total Bitrate: 27.35 Mbps
VIDEO:
VC-1 Video 23068 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio English 2222 kbps 5.1 / 48 kHz / 2222 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio French 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
Dolby Digital Audio Portuguese 192 kbps 1.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics English 17.547 kbps
Presentation Graphics Danish 17.366 kbps
Presentation Graphics Finnish 17.037 kbps
Presentation Graphics French 17.930 kbps
Presentation Graphics Norwegian 15.212 kbps
Presentation Graphics Portuguese 17.300 kbps
Presentation Graphics Spanish 17.767 kbps
Presentation Graphics Swedish 15.961 kbps
FILES:
00020.M2TS 0:00:00.000 1:34:04.597 19,294,752,768 27,346
CHAPTERS:
1 0:00:00.000 0:02:07.127 16,902 kbps 36,056 kbps 00:00:04.212 27,993 kbps 00:00:04.004 22,599 kbps 00:00:02.210 88,965 bytes 263,043 bytes 00:00:09.009
2 0:02:07.127 0:03:16.905 20,744 kbps 28,470 kbps 00:04:45.785 27,881 kbps 00:04:44.450 27,353 kbps 00:04:39.445 108,149 bytes 274,959 bytes 00:05:15.440
3 0:05:24.032 0:01:18.828 26,336 kbps 34,645 kbps 00:06:24.842 31,476 kbps 00:06:24.592 30,228 kbps 00:05:57.648 137,303 bytes 328,684 bytes 00:05:43.051
4 0:06:42.860 0:03:55.026 20,453 kbps 28,280 kbps 00:10:33.382 27,018 kbps 00:10:12.570 26,257 kbps 00:10:09.900 106,630 bytes 259,661 bytes 00:10:16.115
5 0:10:37.887 0:01:53.279 26,728 kbps 33,555 kbps 00:11:19.220 30,302 kbps 00:11:17.051 29,110 kbps 00:11:11.545 139,349 bytes 296,848 bytes 00:11:03.913
6 0:12:31.167 0:04:13.419 23,781 kbps 38,234 kbps 00:15:02.902 33,628 kbps 00:16:10.928 31,324 kbps 00:15:02.860 123,984 bytes 314,470 bytes 00:14:36.000
7 0:16:44.586 0:02:26.229 23,507 kbps 36,667 kbps 00:18:55.759 34,296 kbps 00:18:53.465 30,417 kbps 00:18:50.504 122,557 bytes 320,200 bytes 00:18:56.552
8 0:19:10.816 0:01:53.112 24,409 kbps 40,146 kbps 00:19:43.974 35,316 kbps 00:20:35.359 31,355 kbps 00:20:31.438 127,258 bytes 320,055 bytes 00:19:59.198
9 0:21:03.929 0:01:57.367 23,192 kbps 30,394 kbps 00:21:23.240 29,902 kbps 00:21:22.781 29,355 kbps 00:21:22.614 120,912 bytes 286,138 bytes 00:21:36.211
10 0:23:01.296 0:03:55.026 22,749 kbps 36,835 kbps 00:24:09.739 32,641 kbps 00:24:45.859 29,316 kbps 00:24:42.939 118,600 bytes 349,176 bytes 00:24:10.115
11 0:26:56.323 0:03:32.212 22,198 kbps 44,982 kbps 00:27:50.210 31,251 kbps 00:29:02.282 30,943 kbps 00:29:02.282 115,733 bytes 451,151 bytes 00:27:50.251
12 0:30:28.535 0:03:45.850 24,621 kbps 43,636 kbps 00:32:42.502 35,323 kbps 00:32:42.168 31,483 kbps 00:32:37.705 128,625 bytes 334,667 bytes 00:32:42.210
13 0:34:14.385 0:06:00.401 26,767 kbps 49,555 kbps 00:37:56.607 35,338 kbps 00:38:15.543 32,463 kbps 00:36:27.226 139,550 bytes 390,324 bytes 00:39:08.554
14 0:40:14.787 0:06:49.117 25,210 kbps 45,739 kbps 00:42:46.438 34,939 kbps 00:41:11.844 32,567 kbps 00:44:33.087 131,435 bytes 438,570 bytes 00:41:14.138
15 0:47:03.904 0:03:22.994 16,176 kbps 32,223 kbps 00:47:12.120 31,402 kbps 00:47:08.200 30,208 kbps 00:47:07.199 84,333 bytes 259,934 bytes 00:47:19.795
16 0:50:26.898 0:03:11.566 20,751 kbps 47,575 kbps 00:52:58.884 33,276 kbps 00:52:17.259 30,674 kbps 00:52:17.217 108,184 bytes 387,742 bytes 00:52:59.885
17 0:53:38.465 0:04:23.346 22,521 kbps 45,125 kbps 00:56:40.855 33,861 kbps 00:57:29.612 32,242 kbps 00:56:54.452 117,416 bytes 378,549 bytes 00:57:02.544
18 0:58:01.811 0:02:06.292 27,816 kbps 35,344 kbps 00:59:44.122 32,766 kbps 00:59:03.039 31,029 kbps 00:58:59.410 145,021 bytes 346,461 bytes 00:59:44.664
19 1:00:08.104 0:03:17.071 24,332 kbps 40,252 kbps 01:02:06.514 31,058 kbps 01:00:46.017 29,333 kbps 01:00:41.220 126,858 bytes 318,324 bytes 01:03:25.134
20 1:03:25.176 0:03:39.761 25,367 kbps 41,753 kbps 01:06:25.231 35,404 kbps 01:05:55.576 32,433 kbps 01:03:55.706 132,250 bytes 328,282 bytes 01:03:59.627
21 1:07:04.937 0:03:22.702 24,592 kbps 36,236 kbps 01:08:14.423 33,870 kbps 01:08:11.337 31,668 kbps 01:09:09.061 128,209 bytes 404,454 bytes 01:07:47.688
22 1:10:27.640 0:01:29.923 28,271 kbps 38,955 kbps 01:10:31.185 32,432 kbps 01:11:09.390 31,238 kbps 01:11:04.510 147,390 bytes 358,697 bytes 01:10:31.227
23 1:11:57.563 0:04:04.243 25,654 kbps 45,603 kbps 01:13:55.556 34,745 kbps 01:15:43.747 32,006 kbps 01:15:37.991 133,748 bytes 310,945 bytes 01:13:56.265
24 1:16:01.807 0:03:16.237 25,507 kbps 46,336 kbps 01:17:23.347 33,858 kbps 01:16:44.641 32,545 kbps 01:17:16.548 132,983 bytes 393,083 bytes 01:16:27.499
25 1:19:18.044 0:03:24.287 23,909 kbps 37,703 kbps 01:21:27.924 32,566 kbps 01:21:24.504 31,925 kbps 01:21:22.252 124,650 bytes 335,425 bytes 01:22:42.290
26 1:22:42.332 0:02:21.140 28,691 kbps 57,430 kbps 01:24:36.821 34,873 kbps 01:24:34.194 31,580 kbps 01:23:45.770 149,580 bytes 587,087 bytes 01:24:58.468
27 1:25:03.473 0:01:13.907 28,233 kbps 40,468 kbps 01:25:59.320 33,872 kbps 01:25:57.986 32,670 kbps 01:25:39.717 147,443 bytes 374,631 bytes 01:26:15.170
28 1:26:17.380 0:02:05.875 14,084 kbps 22,068 kbps 01:26:33.354 21,445 kbps 01:26:32.854 19,741 kbps 01:28:09.450 73,573 bytes 156,821 bytes 01:26:48.077
29 1:28:23.256 0:02:46.166 25,649 kbps 40,424 kbps 01:30:04.524 35,280 kbps 01:30:04.524 31,861 kbps 01:30:03.940 133,723 bytes 330,891 bytes 01:30:04.565
30 1:31:09.422 0:02:55.175 3,504 kbps 10,935 kbps 01:33:57.882 5,241 kbps 01:33:57.548 4,348 kbps 01:33:05.079 18,424 bytes 196,322 bytes 01:33:10.543
STREAM DIAGNOSTICS:
00020.M2TS 4113 (0x1011) 0xEA VC-1 5644.472 23,068 16,276,177,768 88,539,108
00020.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5644.472 2,222 1,567,818,836 9,447,634
00020.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 5644.472 192 135,470,592 881,970
00020.M2TS 4354 (0x1102) 0x81 AC3 por (Portuguese) 5644.472 192 135,470,592 881,970
00020.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5644.472 18 12,380,426 71,822
00020.M2TS 4609 (0x1201) 0x90 PGS fra (French) 5644.472 18 12,651,154 72,941
00020.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 5644.472 18 12,536,179 72,422
00020.M2TS 4611 (0x1203) 0x90 PGS por (Portuguese) 5644.472 17 12,206,616 70,662
00020.M2TS 4612 (0x1204) 0x90 PGS dan (Danish) 5644.472 17 12,253,151 70,631
00020.M2TS 4613 (0x1205) 0x90 PGS fin (Finnish) 5644.472 17 12,021,135 68,998
00020.M2TS 4614 (0x1206) 0x90 PGS nor (Norwegian) 5644.472 15 10,733,199 61,879
00020.M2TS 4615 (0x1207) 0x90 PGS swe (Swedish) 5644.472 16 11,261,682 64,332
