AVS › AVS Forum › Audio › Speakers › Just bought Monitor 70 speakers...bass?
post #1 of 7
I have read plenty of reviews that Monitor 70 speakers have great bass without a sub woofer but I have yet to hear said bass...does the bass improve over time? Maybe I need a stronger receiver (I have a 100 watt per channel)??
post #2 of 7
great bass from a floorstander is not like great bass from a sub. a floorstander is not going to shake your room
post #3 of 7
My receiver sounds very flat when im in certin sound modes. Its only when i change to a music mode or even use it in stereo it seems to really fatten up.
I think the idea is to let the surround track in the movie dictate how bass heavy the sound is.
Also when i listen to music i set my speakers to large so they get the full range of sound.
post #4 of 7
Will have to agree. For me, floorstanding speakers alone just don't cut it as far as bass is concern. I need subwoofers.
post #5 of 7
Check your receiver settings? Their bass is pretty good but for HT especially no substitute for a subwoofer.
Ron
post #6 of 7
Well there's your problem. If you don't have a sub, the speakers should always be set to Large. Otherwise your receiver thinks there's a sub.
post #7 of 7
Ron
Agree'd. Make sure your AVR is squared away, let the speakers break in for a little bit, and then see if you need to change your speaker and/or seating position. You won't get twin 15" subwoofer bass, but they shouldn't be like anemic bookshelfs either.
  Back to Forum: Speakers
