I did search for this and didn't find anyone with the same symptoms that I have. I think I just have a simple question though - I have an ADCOM 5.1 system with an amp (GFA-6000) and pre-amp/tuner (GTP-750). I've had them for a long time in multiple houses with lots of animals, so I think there is probably a dust / hair issue.
I am getting crackling sounds in every speaker, sometimes with nothing currently playing (DVD / Video Game paused and still making sound) it's not consistent at all, but can get very annoying.
Basically I'm just trying to figure out which part of the system would be the one making the sounds, the AMP or the PREAMP?? I'm sure most answers will be "both", but if you had to pick, which is more likely the issue?
And should I be able to clean them out myself with not a lot of experience in this area, or have a professional do it?
