AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Samsung BD-C5500 master owner's thread
Official Samsung BD-C5500 master owner's thread - Page 43
post #1261 of 1610
After all the reading and playing with my BD-C5500, I have decided to keep it rather than upgrade to the 3D BD-D5500. Now the problem is that my current firmware is very old 1010 version and Samsung recommend to upgrade to the newest 1022.3 firmware.
My problem is that I do not use the internet to stream video, I don't play Blue Ray disc, the only thing I use this player is to play all the videos that I have downloaded onto my 500GB external Hard disc which is connected to the front USB slot. Right now, it plays AVI, WMV and MP4 files with the fast forward and rewind working just fine. It doesn't play the .VOB files however I do have those on the original DVD so it is not a really big problem for me.
I would love to have the latest updated firmware however are worried because some of the guys here had problems after upgrading to the 1022.3 firmware but most of the problems are related to video streaming.
Since once the new firmware is installed, it can not be reversed. I am trying to find out if there are other problem that you guys saw after installing the new firmware?
I know I have been asking a lot of questions here and I would like to thank all the people that have responded but I just want to get as much information as possible before making deciding and you guys are a wealth of knowledge here. Thanks for any help.
post #1262 of 1610
Definitely update from the old 1010 firmware. But you might want to go with the 1021 firmware for the moment, since 1022 seems to cause problems with ff/rw in playback of local file formats that worked with 1021. You can't do that by online firmware update, you'll have to download it and install it manually.
post #1263 of 1610
Follow this process:
1) upgrade to 1022.3
2) rip your DVD using DVD Decrypter [free] or ANYDVD [$$] to Video_TS directory [not ISO]. DVD Decrypter will handle 95% of your DVD's.
3) Re-author [essentially remuxing] the main video and audio to one large file using DVD Shrink [free]. Make sure that you use NO COMPRESSION [3-5 minutes].
4) drag and drop the VOB file ONLY to your MediaShare folder
5) enjoy...
The VOB file is a relabelled MPEG2 file, hence no problems with Samsung.
Kurt
post #1264 of 1610
Can someone tell me where I can find the 1021 firmware? Called Samsung and they said that they only have the latest firmware and do not keep the old firmware.
I tried Googling the 1021 firmware however there is nothing out there. I am hoping that someone here have kept a copy of 1021 firmware and would be able to e-mail it to me.
post #1265 of 1610
5) enjoy...
Kurt
Hi Kurt, thanks for all your response and help here however since I have the DVD in my collection so being able to play the .VOB is not that important right now. I am also not that tech and I really only understand half of what you are telling me so I am just going to use my DVD if I want to watch it. Thanks again for your time.
post #1266 of 1610
You can find it by googling "BSP-C5500WWB-1021.4.zip" and picking the samygo.tv link - I would post the web address but this site won't let me.
Andy
EDIT - Now I've made 3 posts, I can add the web link: it's at http://downloadcenter.samsung.com/co...WWB-1021.4.zip
post #1267 of 1610
Andy
Thanks to the information you provided, I found it and have downloaded it. The knowledge and help on this forum is great. Thanks again for the help. I hope I am all set now.
post #1268 of 1610
Sorry to bother you guys again however does anyone know if there is any way I can check to see how many hours were used on my Manufacturer refurbished BD-C5500? I know that on some DVD recorder, there is a way to find out how many hours the DVD recorder have been used. Thanks
post #1269 of 1610
I just hooked up a used c5500 that I picked up and I'm running optical to my 6.1 receiver. However, my receiver is only displaying 5.1 DTS during BR playback. I've tried to tweak the audio settings (Bitstream-reencode and Bitstream-audiophile), but always get the same result.
I had a (junky) Memorex BR player that sent discrete 6.1 DTS-ES over coaxial. Doesn't this player support 6.1 over optical? After years with 5.1, I finally hooked up a rear center and now it's non-functional!!
post #1270 of 1610
I think it only goes up to 5.1 (Dolby Digital or DTS) over optical - for 6.1 or 7.1, you need to use the HDMI output.
Andy
post #1271 of 1610
That's odd, because even SD DVD players can pass DTS-ES 6.1 over optical or coaxial. I wasn't expecting 6.1 or 7.1 lossless, but DTS-ES 6.1 is a "legacy" extension to the DTS core and I don't see why it wouldn't work over optical. In addition to my old Memorex, I believe the PS3 handles lossy 6.1 over optical.
I've only tried a single BRD on the Samsung so far (Tron Legacy), so maybe it's a content issue?
Andy
post #1272 of 1610
The HT-C5500 doesn't support DTS ES Discrete 6.1 (see http://www.amazon.co.uk/Samsung-HT-C.../ref=de_a_smtd) - and this system is based on the BD-C5500, just with added speakers. So you might be out of luck.
post #1273 of 1610
New firmware 1023 today! Mkv. ff and rw ...... still aint working!!!!!!! There must be bunch of apes working at Samsung FFS!!!! Idiots....
post #1274 of 1610
Have you tried remuxing your MKV files with an older version of MKVMerge? This worked for me and others.
It might not be a Samsung issue.
Kurt
post #1275 of 1610
I spent plenty of time figuring out which options in Handbrake would produce an MKV file that works properly on the Samsung players. Now I have lots of them. I don't know about you, but I'm not keen to remux them all because Samsung broke something in firmware release 1022. I'm sticking with 1021 until someone tells me that this problem has been fixed.
post #1276 of 1610
Fw and rw worked fine in every .mkv´s before 1022.3 update. After that update it stop working. So its surely Samsung issue. If you now must remux your MKV files with an older version of MKVMerge, something is very wrong in these last updates.
Edit: amesdp, wisely done. If I could just return to that 1022.2
post #1277 of 1610
While my -> and <- worked, my "Tools" did NOT work until 1022.3. I had no way of moving to a specific time in an MKV. So spending the 3-5 minutes to remux films that I need to move around in [like music videos] is well worth 1022.3.
It's interesting that a simple change to a muxing protocol affects the ability to use these movement tools. Does anyone know what exactly changed with MKVMerge 4.0 and higher?
Kurt
post #1278 of 1610
My point is that MKVMerge may be using a protocol that is not standard YET. And the fact that some of our movement tools worked with the new protocol was perhaps fortunate.
Either way, I wouldn't count on Samsung to be proactively solving this issue on the near future.
Kurt
post #1279 of 1610
Does anyone know how to access service menu? Thanks.
post #1280 of 1610
More problems with the new update Im watching normal Terra Nova.avi and the player suddenly stops after 3 mins and goes back to to video-menu. Same happened couple hours ago when I was watching The Ultimate Fighter.avi, few minutes and stop ---> video-menu. Wtf is going on? I have re-started all devices between these videos. Watched 2 videos, both stopped after couple of minutes.
post #1281 of 1610
Kurt
My MKV files produced by Handbrake (H.264 video and AC3 passthrough audio) all work just fine with firmware 1021, i.e., they all ff, rw, goto time code on the Tools menu correctly.
On the other hand MKV files produced by MakeMKV did not work well at all - they played, but any attempt at movement resulted in a quick zip to the end of the file.
post #1282 of 1610
the update from last month disabled my BD playback, only normal dvd's worked. Yesterdays update got the BD disks working but they freeze up after about 20 minutes into the movie. I've tried all BD disk I have and they all freeze up sometimes after a few minutes or longer. It seems to be certain parts on all the disk because even when I power off, eject, reload,and skip to the time, it will freeze on all my disks. Any clue why?
post #1283 of 1610
I have owned my C5500 now for about 1 year, in that time I've enjoyed everything about it with the exception that the recommended apps in the main screen is controlled by Samsung and not us, other then that this is the best BD I've used yet. I have a Panasonic DMP-BD65 also, I like the remote of the Panasonic but that's it.
post #1284 of 1610
^^^ likely getting some kind of kick back from those companies
post #1285 of 1610
Just got this new Samsung BD-D5500 ,
Plug an external USB hard drive 1TB fomated in NTFS , can handle almost any MKV files , 720p , 1080p. Multilanguage.
Everything play smooth ,ive tried several blu-ray 3d player (Sony S470 - Panasonic BDP-110 ) and this Samsung give me the best result yet.
I want to know if there is a way to put a cover art to the MKV file's thumbnail
in the navigation system,
that would be awsome
thank you
post #1286 of 1610
^^^Not using Samsung software (unless they have updated - no longer using it) but other server software does. I know you can with Mezzmo.
post #1287 of 1610
serviio does cover art aswell doesn't work very good pic's are tiny
post #1288 of 1610
What many fail to realize is the framework/structure on the players/TV is down to the manufacturer of the player/TV.
Those creating the server software (e.g. Mezzmo, Serviio) have to live within the confines of framework/structure on the players/TV
post #1289 of 1610
EDIT: My bad, it was 1023.0, not 1030.
post #1290 of 1610
I think any chance of getting improved functionality is remote:
Originally Posted by Samsung US View Post
Ver.1023.0 Oct.06.2011
- Improve specific disc''s playback capability.
Ver.1022.3 Sep.09.2011
Ver.1021.1 Apr.22.2011
- Improved specific BD title''s playback compatibility
Even PCSM is still ver4.2 from Jul 10. Has anyone tried AllShare and compared to PCSM. Is it still pile of junk? Is it compatable with older players?
