AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Samsung BD-C5500 master owner's thread
Official Samsung BD-C5500 master owner's thread - Page 44
post #1291 of 1562
Hi,
Thinking about buying this bluray player, what are the major differences between this one and the 2011 model (D5500) other than 3D stuff?
Also, does anyone know if it's possible to change the Internet@TV region on this player (I don't mean the bluray/dvd region) to another country like with the TV? (i.e. with the >>, 289, << trick)
post #1292 of 1562
How come this player will not play some of my DVD's? The dads that I want to play were recorder in other regions which are non NTSC. I was told this player should play all DVD's do I need too upgrade the firmware? I brought this maybe 6 months ago and never got to hooking it up until now due to personal reasons.
Any advice will be great.
Thank You
post #1293 of 1562
I have a samsung bd-c5500.
while using internet application and watching them, the "samsung" logo screen saver kicks in.. there have been other threads on this but one of them was 25 to 50 pages long..
Has anyone found an answer to this?
I did update to latest firmware
post #1294 of 1562
Have you searched in the owner's thread? All player realted posts go there.
http://www.avsforum.com/avs-vb/showt...light=bd+c5500
S~
post #1295 of 1562
I am using a wireless dongle and am getting good results. However, when I put a USB storage device (2gig) in the front slot, it is not recognized by any disc or BDLive as additional storage. Anyone know how to get the unit to recognize the front USB as additional storage? It works when I have music or pictures, but NOT for storage.
Classico
post #1296 of 1562
Is that an empty memory stick? The player seems to require a certain amount of free memory on the stick before it will use it.
post #1297 of 1562
Yes it is with 2g free memory
post #1298 of 1562
Hi,
I've tried to search this thread but couldn't find the answer. When playing Blu-Ray discs I have no problem with TrueHD or HD-MA, it send it to my NAD receiver quite fine. For MKVs though it gives an "incompatible audio" error, or otherwise doesn't show an error but simply doesn't play audio.
Is HD audio in MKVs not supported or am I doing something wrong? I've checked the files and they otherwise play fine, and I've ensured there is no header compression, any other audio tracks in the file play fine, it just wont bistream.
post #1299 of 1562
post #1300 of 1562
How is it formatted?
You can use NTFS for data playback but BDLive requires FAT as the format method. You also have to go into BD Data Management and tell it to use the device for storage each time you plug it in. (pg 35 in my version of the owner's manual)
post #1301 of 1562
I will try finding that (BD Management) and be sure that I do have a FAT format. I will let you know my results.
Classico
post #1302 of 1562
Has anyone found the answer to this?
post #1303 of 1562
What particular application are you talking about? I only really use Netflix and local streaming and only time I get the screensaver is if streaming music only.
post #1304 of 1562
Thanks for the help. I did need to reformat to FAT. Now it works EXCEPT with 20th Century Fox titles. OK I tried TWO. Neither Avatar nor Narnia/Dawn Treader, Sound of Music works when the BD Manager recoginzes the memory. When I remove the memory the movie loads and plays; otherwise it freezes.
So far WB, Disney and Paramount all work, so whats up with Fox?
Classico
post #1305 of 1562
BDC5500
1) 1023 firmware will not download - the progress bar keeps resetting to 0. Closest I've ever gotten to 100% is 75%...
2) VuDu will not finish its upgrade - locks up at 100% and doesn't complete. Hence, I am unable to use any apps except those in the favorite bar, since everytime I go to the apps area, it automatically tries to upgrade VuDu.
3) Other funky issues with the last Mezzmo upgrade. Primarily related to the server disconnecting for no reason.
Any comments/help would be appreciated. Thx
Kurt
post #1306 of 1562
Originally Posted by kws53 View Post
BDC5500
Kurt
have you tried updating using the usb method you can download the firrmware from samsungs website. other note just received the 1024 update this morning anybody have any ideas what it updated?
post #1307 of 1562
Tried downloading 1024. After 4 attempts, it succeeeded in finishing the download but failed to install, giving me an installation error.
Might be time to do a hard reset on the player? I'll hunt to see what this involves...
On another rant, it feels like Mezzmo is transcoding everything now and I can't figure out how to turn it off.
Kurt
post #1308 of 1562
Are you sure your using the correct device profile?
post #1309 of 1562
Well that's a great question. Ever since the last upgrade [2.4.5], things have been wonky [disconnects - which implied transcoding...]. The only solution I could find that allowed some semblance of similarity to the previous release was using the 3D version of the profile.
By comparing the two profiles, I've been attempting to determine the differences. I'll try and make the regular profile work based on your comments here.
Kurt
post #1310 of 1562
I'm using Samsung BDP on all mine but I completely turn all transcoding off.
post #1311 of 1562
Has anyone here successfully loaded Plex Laika?
I have added the app to internet@tv, put when I try to open it, it can't connect to my network/server.
post #1312 of 1562
Anybody had a chance to try the new firmware version 1024 with playback of mkv files yet? Have Samsung broken anything new?
I see that firmware version 1024 adds support for CinemaNow in Canada - not that it's likely to see much use with even old movies renting for $4.99 per view and no promotional offers to try it out.
post #1313 of 1562
haven't seen any new issues with it but still need to make sure mkv's were made with older versions of mmg if you want to fast forward or skip.
post #1314 of 1562
Kurt
can't help you much with mezzmo, i use serviio for mine. after one of the firmware upgrades serviio decided it didn't want to use the samsung profile and it kept disconnecting like your's is i uninstalled/reinstalled and then it kept the profile setting
post #1315 of 1562
Have the latest FW. Tried playing this file via USB. It's a .avi container with mpeg-4 video codec and the following AC3 audio codec. It will play the video, tells me the audio codec is not supported, and there is no sound. Other files with AC3 audio play just fine. How can it support some AC3 and not others?
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 00001000-0000-0020-8000-00AA00389B71
Duration : 1h 52mn
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 131 MiB (9%)
Interleave, duration : 88 ms (2.64 video frames)
Didn't try this before the FW update
post #1316 of 1562
My Samsung BD-C5500 connects beautifully to my MythTV server (via DLNA) and plays all the captured MPEG-2 files brilliantly. I can skip forward (> key) and back (< key) on files recorded from the local PBS affiliates (KRMA and KBDI in Denver), but not on any of the recordings of programs from commercial stations.
Is there some flag embedded in the recorded streams that allows or denies skipping capability on this player?
On all programs, the "real" skip-back key (|<<) jumps back to the beginning of the file, but neither the skip-forward (>>|), fast-forward (>>) or fast-reverse (>>) keys work on any recorded programs.
Jim McCauley
Fort Collins CO
post #1317 of 1562
Audio
Format : AC-3
Duration : 1h 52mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Try a recode using FFMpeg to MKV. IOW, ffmpeg -i input_file -vcodec copy -acodec copy out_file.mkv . It should play the audio then.
post #1318 of 1562
Thanks! It worked
post #1319 of 1562
What's the best known "good" firmware version? 1021.4?
Or has 1024.0 fixed the issues experienced since 1021.4? (ff/rw mkvs in particular)
post #1320 of 1562
Firmware versions may often just be keeping up with the latest tricks the studios want to put in their DRM. This is the downside of Bluray that unless the user keeps up with these they may find a new disc that won't play.
