Originally Posted by roccol
I'm not sure what the tv has to do with any of this. I keep the tv volume at zero. I have hdmi going from bdc5500 to TV. I have optical from bdc5500 to digital receiver.
I have the receiver set to auto surround and the bdc5500 set to bitstream. When I try setting it to pcm, I get great voice dialogue, but only 2.1 sound. The only other sound option is for true hd and down mixing. My receiver doesn't support true hd. I will check the down mixing.
I did not have a chance to respond until now. I should have said "receiver" instead of "TV". You have probably already tried this, but be sure the player is set to "Bitstream-reencode", since you are using the optical connection to your receiver. Then, see if the receiver tells you what surround mode it is in. It should be in DTS mode. This is assuming your receiver can decode DTS. If it cannot, you may need to set the player to "bitstream-audiophile" mode for Dolby discs and "PCM" (losing the surround tracks) for DTS discs until you upgrade your sound system. I do not know what "auto-surround" is, so try to manually change the receiver into Dolby Digital and/or DTS modes. Also, see the notes on pages 32-34 of the player's manual regarding sound output formats.
Last, the TV's HDMI input itself may be causing the problem. Quite possibly, the TV cannot accept a DTS signal input, so the player will change the output format of the HDMI sound-and then also the optical output-to whatever the TV can accept. The test for this problem would be to try using the component output into the TV (and disconnect the HDMI cable) and see if your sound changes.
updated the firmware ok,only watched 1 movie so far but pleased and looking forward to future movie watching.
