AVS › AVS Forum › Video Components › Home Theater Computers › * Official * Cyberlink PowerDVD 10 Ultra thread
* Official * Cyberlink PowerDVD 10 Ultra thread - Page 36
post #1051 of 1608
No, it's not the latest patch released yesterday. I did experience the issue with PowerDVD 10 and now still with the Mark II update from a little while back. I will have to look into the latest patch.
post #1052 of 1608
I don't think the latest patch will fix it. Something else is going on there as I don't have that problem and never have.
post #1053 of 1608
Originally Posted by ricabullah View Post
Test BD : 2012
Player: PDVD10 v.10.0.1830.51
OS: Seven 32 Pro
HW: Clarkdale+Ati 5450 LP
Drivers: CCC 10.8
Connection Style: VGA to AVR, AVR to TV over HDMI cables.
Test result:
After skipping to sixth or seventh chapter i met silent stream bug...
_ _ _ _ _
Silent stream bug shifted to the eleventh chapter with the new patch.
EDIT: Now i'm shifting to my 460 and i don't need any bug anymore there
post #1054 of 1608
Originally Posted by mcantu1 View Post
build 2113 is now out...http://www.cyberlink.com/downloads/s...es_en_US.html#
So, this killed my 3D output and I still don't have Bit-Streaming capability.
PDVD 10 MK II 2113
GTX460
Onkyo 805
Mitsu 3D Rear Projection.
3D was working with the previous PDVD build.
post #1055 of 1608
PDVD 10 MK II 2113
GTX460
Onkyo 805
+ still no audio on media center on cinema mode
post #1056 of 1608
Tom please have a look at this
http://www.avsforum.com/avs-vb/showp...&postcount=406
_ _ _ _ _ _
post #1057 of 1608
PDVD 10 MK II 2113
GTX460
Onkyo 805
Are you using the latest NVIDIA driver? For the Mitsubishi DLP TVs, you need to choose "3D Ready TV" for your 3D output settings. This puts out a checkerboard signal. You don't want to output HDMI 1.4.
Tom
post #1058 of 1608
Tom
I have the latest NVIDIA 260.63. I tried every output option, non will turn on the emitter except for "CRT Display". Then the glasses work but it's shutter is all messed up on the right side. When I put to the setting you say, which is where I had it when it worked on the old build. It looks like it's right on the screen, but the emitter will not turn on, and neither will the glasses. All worked before.
3D does work with NVIDIA's 3D Test and Games, not thru PDVD.. Pretty sure its just something with PDVD talking to the NVIDIA 3D Driver, the image PDVD is outputting is the same and when it worked. Definitely Checkerboard
I also retried with the older 258.96 NVIDIA drivers, same thing no 3D..
Side note. I got bitstreaming to work after closing AnyDvd HD
post #1059 of 1608
So, in device manager I found that the Nvidia Stereo driver somehow got uninstalled with their latest drivers, kinda weird. So, I installed the driver.
Now I was able to get 3D output only by selecting the HDMI 1.4 or Nvidia 3D display options in PDVD, when I select the option for checkerboard, the emiiter turns off and no more 3D, but then the High-Definition option for Bit-Streaming worked. CRAZY!
In the other modes, PCM Decoded by PDVD or High- Definition Pass through, leave me with no sound. This is all very interesting and I spent over 5 hours, trying everything.
So, either 3D with just normal Dolby Digital/DTS pass-through, using the 1.4 HDMI or Nvidia display option
or
High Definition audio pass-through and no 3D, and using the "Checkerboard option"
<---------Scratches his head
post #1060 of 1608
So far everything is working correctly with my GT 220 I'm able to watch blu ray 3d and regular 2d to 3d SD DVD. With the latest beta drivers and the latest Cyberlink build it's the first time I was able to get everything working for 3D. My receiver is in the shop so my PC and everything is going to the Panasonic 3D TV.
Another plus about the beta drivers is now I can leave my PC in Cinema mode and run the 96Hz option without flicker so everything for me on my end has been a plus. Again 3d is working with my GT 220 and the latest sw/drivers.
Watching Jurassic Park right now it looks pretty good but faces get deformed a bit looks pretty funny.
post #1061 of 1608
That's very interesting. Unless I'm reading this wrong the lowest officially supported card is the 240, didn't think to actually try it
post #1062 of 1608
Your reading it right no doubt about that, I'm glad I didn't have to break another "C" note for another freakin card. I'm watching Das Boot full DVD version and I must say 3D really looks good on this movie. Definitely had to tone down the depth for 2D/3D content, people were looking way funky.
Oh jeez forgot to image the drive gotta keep this config for sure, who knows what will happen when the final drivers come out.
Oh I forgot to mention this on Win7 x64 i5, GT220 and using my Panasonic shutter glasses.
post #1063 of 1608
I just tried it out with a 210 and it does work, but only in the loosest definition. The BD plays and renders in 3D, but it's obvious that the card is really struggling.
post #1064 of 1608
Tom,
why is it not possible to adjust the color settings when playing a BD?
post #1065 of 1608
When I put in a blu ray 3D I get this weird noise and it's intermittent in certain scenes. I don't know if it's a driver issue or what being that these are betas but as far as playback on the GT 220 it's very smooth and doesn't seem to struggle at all. If I put in a DVD the conversion works perfect and zero noise, but if I put in a regular 2D blu ray and keep Cyberlink in 3D mode the noise is more consistant this only happens with blu ray 2D or 3D when in 3D mode.
But this isn't important to me because I really wanted 2D to 3D for SD DVD's and I got exactly what I wanted with the updates. Since there is really nothing to watch right now for blu ray 3D this will tie me down until I get my two copys of Coraline and what ever the other one was can't remember. And It's been close to 6 weeks since I mailed in for my promo discs.
The 3D SD DVD upconversion is only 720p but I got to tell you it really looks damn good. Watching Star Wars, and man it looks almost like BD material due to such a good transfer on these DVD's. Regardless Cyberlinks DVD playback is very good at upconverting Sd material and I am actually surprised it actually works!
post #1066 of 1608
Is anyone still having problems with the navigation frame NOT fading with this latest patch? I am.
post #1067 of 1608
I didn't try any 2D->3D conversion, just a few minutes of Coraline and Ice Age Dinosaur something (which actually looked really good when it wasn't stuttering).
post #1068 of 1608
I think the workaround is to launch your movies with 3D off then hit the switch to enable it. Then the player acts normal, mouse cursor and navigation bars drop out.
post #1069 of 1608
OK guys i have to admit PDVD10 is working with new beta drivers over nVidia cards:
http://www.avsforum.com/avs-vb/showp...&postcount=448
_ _ _ _
post #1070 of 1608
Originally Posted by Andy o View Post
The problem I think is for ATI cards. There are several fixes and workarounds, depending on what series and driver version.
Thanks for the feedback..so not 100% clear on black levels
I think I will stay with the setting I have now just to play it safe.
Win 7 32,
ATi 4850 cat 10.5
X-Meridan 7.1
PowerDVD 10 First build
Corel Windvd 9 B14.084 (only build with correct Black levels)
AnyDVD upto date as required
DVI-Infocus In83
post #1071 of 1608
Right. The 5000 series came with a new setting in the Video tab of CCC that let you choose levels. It helped a lot, but it didn't make things perfect for everyone still. I don't know why they didn't add that to the previous series of cards.
post #1072 of 1608
Just to make me mad, that's why. I can't wait for the 450 to get here. I have some things I wanna try with it.
post #1073 of 1608
I still can't get 3D and Bitstreaming to work..
In process of an erase and clean install of w7, will report back
post #1074 of 1608
Tom
Well, my issue with VC-1 & PowerDVD 7.3 Ultra being broken:
Full reinstall of Windows 7 failed. Fresh system, latest updates & drivers. PowerDVD 7.3 will play anything as long as it isn't VC-1 encoded.
post #1075 of 1608
So, did a new install of W7, with just the new Nvidia 260 Drivers (Including the USB Emitter Driver which is separate BTW) and the new PDVD 10 MK Build. Issue persisted, no 3D using even just the NVIDIA 3D Test. I found alot out though.
I could get 3D working if I bypassed my Onkyo 805 and used the DVI-HDMI cable from the GTX460 to my Mitsu 73738. Then 3D will work, but even still PDVD won't turn on the emitter unless I select the "Hdmi 1.4 Enabled TV" or the Nvidia 3D Vision Monitor" options. Then everything is fine.
Looks like both NVIDIA and PDVD have separate issues. Until this is worked out, I am going back to the NVIDIA 1.33 Beta 3D Vision drivers with the Previous PDVD 10 MK2 Build, because that was working correctly.... Just no Bit-Streaming of HD-Audio.
I wonder if this all has to do with HDMI 1.4 and the Onkyo only being 1.3... Tempts me to get a New 3D ready HDMI 1.4 Receiver to try out.
post #1076 of 1608
Switched back and everything works, just no Bit-Streaming, just as before. I even attempted to trick it with the New NVIDA HD Audio Driver for the HDMI... The High-Definition Audio option shows in PDVD, just has no sound when selected, both the other options produce sound.
Reminds me of the days when ATI first started bitstreaming
post #1077 of 1608
I have tried the following setup:
Win7 32-bit
NVIDIA beta driver 260.63
PDVD 10 MK II 2113
GT 240
With the new NVIDIA 260.63 Beta driver we know bit-streaming is now possible with at least the GTX 460 card (& maybe other 4xx cards) but what about this:
 Adds high definition 24-bit, 96 and 192 KHz multi-channel audio sampling rate support for compatible Blu-ray movies with GeForce GTX 400 Series ,GT 240, GT 220 and 210 GPUs*. *Note: A Blu-ray movie player update may be required to enable these new features; check with your movie players software manufacturers for more details.These features are only supported on Windows 7.
Based on NVIDIA's beta driver I was hoping to get bit-exact LPCM playback from my 24-bit movies but PDVD10 build 2113 still reports 16-bit (used Star Trek - TrueHD 24-bit as an example) . Is there something that PDVD10 needs to do to allow this? I was hoping Build 2113 would work since it was updated for bit-streaming. I'm not sure when I'm going to a GeForce 400 series card for true bit-streaming but this would be a welcome addition for my GT 240...
jidelite
post #1078 of 1608
Win7 32-bit
PDVD 10 MK II 2113
GT 240
jidelite
I'm sorry, but Blu-ray audio bitstreaming is not supported on the GT2xx boards. This is a misprint. I'll make sure that the release notes are corrected.
Bitstreaming is only supported on NVIDIA's GTX460 and GTS450 today (as well as all AMD Radeon 5xxx cards, and systems with Intel HD graphics).
Tom
post #1079 of 1608
Tom
Tom, Thanks for replying... I'm not looking to bitstream with the GT 240, I'm looking to get the 'non-downsampled' rate for BD movies via PDVD10 decoded LPCM. So if a movie has a 24-bit sampling rate, I'm looking for PDVD to say 24-bit and not 16-bit. Sounds like NVIDIA is supporting it so how about PDVD10 under Win7?
jidelite
post #1080 of 1608
so finally it is possible to enjoy real 3d blu-rays with PC! now I have to switch from ATI to NVidia, can someone please tell me where I find a list of cards that have HDMI 1.4 and can output 3d in 1080p?
also I don't understand the audio issue...is it possible now to output audio via the graphic card? I don't need the auzentech $200 card I had in mind?
thanks for clearing things up
