Originally Posted by CyberlinkUSA
I had no problems playing a Blu-ray disc with external decoding (HDMI bitstreaming), either in normal 2 foot mode, or (later, after setting PDVD to bitstream) when launched by Windows Media Center (which always causes PowerDVD to run in Cinema Mode).
My test system: Win 7 Ultimate 64, Intel Core i3-550 CPU, ECS H55H-I Mini ITX Motherboard, NVIDIA GTS-430 graphics with latest drivers... connected through an Onkyo TX-SR508 AVR to a Panasonic TCP50VT20 TV.
Tom
Tom
Tom,
I spent nearly 4 hours installing and imaging machines with Acronis going back and forth with 32bit windows 7 and 64bit windows 7. After 2 installs of 32bit and 2 of 64bit, I have concluded the issue is with 32bit Window 7.
Everything else being equal... It works with 64bit windows and does not with 32bit windows. I get no sound in cinema mode in the 32bit install. It appears to work ok with 64bit.
This is a core i5 system, 4 GB ram, GT 430.
Can you please retry your lab setup with 32bit? This might explain why some are having the issue and others aren't. If you can show this to your engineers perhaps if you can replicat the issue as well.
thanks!
Of course it does!
