AVS › AVS Forum › Video Components › Home Theater Computers › * Official * Cyberlink PowerDVD 10 Ultra thread
* Official * Cyberlink PowerDVD 10 Ultra thread - Page 6
post #151 of 1608
Originally Posted by DMD61 View Post
I used the same glasses used for the movies (Real D 3D) but I could not see any effect by selecting the 3 modes available.
Which sunglasses are suited to see the 3D effect?
THANKS
It all depends on which type of 3D display you have. Most 3D TVs require active shutter glasses. I believe the iZ3D and Zalman monitors use the passive polarized glasses that you tried.
post #152 of 1608
Well no PM and no further FU. I guess since the engineeres couldn't replicate the problem it must not exist. And of course no body contacts me to get more info. Oh well, this is how you lose customers.
post #153 of 1608
Originally Posted by renethx View Post
You can use CyberLink Video/SP Decoder (PDVD10) for MPEG-2 freely with any DirectShow player.
You can't use CyberLink H.264/AVC and VC-1 Decoder outside PowerDVD (7.3 build > 4407, 8 build > 2217, 9/10 [all builds]).
Not true.
post #154 of 1608
Originally Posted by Rathbone View Post
Not true.
You are right. Looks like I was still in the PDVD8 era in this point.
BTW does the decoder really work for VC-1? VC-1 tweak is necessary to make CyberLink VC-1 decoder in PDVD7.3/8 work with Haali/Gebest splitter...
post #155 of 1608
We have the info we need, thanks. Engineers are still working on the issue. I hope I didn't create the expectation that this issue would be resolved overnight.
Tom
Cyberlink
post #156 of 1608
Not true.
Thanks - I have the filters working in an external directshow player (mpc-hc to be precise), but I can't get dxva working with any of them. I've tried using both a 5450 and 9400m. Did you have any luck?
post #157 of 1608
Tom
Cyberlink
How about the video disappearing when FF or RR using that Intel Clarkdale board I mention before? I haven't heard anyone say they've tried PWDVD 10 with it, so I assume its a bug. 9 works fine so I assume its a Cyberlink problem. But I cannnot really use it with FF going black on me.
post #158 of 1608
Was there even a public beta of this software? It probably would have helped iron out these massive bugs before you RTM'd it.
post #159 of 1608
Curious to try PowerDVD 10, I installed the trial version but the application wouldn't start with an error message
"Cyberlink PowerDVD 10 is not optimized for this screen resolution and will now close"
I run Windows 7 64 bit and I have Arcsoft TMT 3 installed.
post #160 of 1608
Hi Eugen,
Can you tell us your screen resolution? What type of graphics card do you have? What is your graphics driver version?
Tom
post #161 of 1608
No Enable Quick Review In Pause
Code:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\\Software\\CyberLink\\PowerDVD10]
"UI_EnableQuickReviewInPause"=dword:00000000
post #162 of 1608
Not true.
Could you explain to a noob what program that is and how you get the filters working in another player such as MPC-HC. Thanks
post #163 of 1608
A video decoder for H.264/VC-1/MPEG-2 (a "VC-1 loader" is necessary to use it for VC-1; see below). Add it to External Filters and set it to Prefer.
In case you are not sure hardware acceleration is working, make sure that "DXVA" is selected in "Properties" (to open it, double click "CyberLink Video Decoder (PDVD10)" in External Filters):
Using CyberLink Video Decoder (PDVD10) for VC-1
The reason why CyberLink Video Decoder (PDVD10) (or any previous CyberLink VC-1 decoder) does not connect to a splitter for VC-1 is the lack of the VC-1 media type (it uses an uncommon GUID {D979F77B-DBEA-4BF6-9E6D-1D7E57FBAD53} for VC-1). A quick way to use it for VC-1 is register a CyberLink VC-1 loader (originally written by madshi):
- CLVC1Loader_MPCMPG.ax for MPC - Mpeg Source (Gabest)
- CLVC1Loader_MPCMKV.ax for MPC - Matroska Source
Input/ouput of these filters are:
- VC-1 input: {31435657-0000-0010-8000-00AA00389B71}
- VC-1 output: {D979F77B-DBEA-4BF6-9E6D-1D7E57FBAD53}
These filters can be connected to any of:
- CyberLink VC-1 Decoder (PDVD7.x)
- CyberLink VC-1 Decoder (PDVD8)
- CyberLink Video Decoder (PDVD9)
- CyberLink Video Decoder (PDVD10)
with the highest merit value.
Another quick way specific to MPC HomeCinema is add GUID of VC-1 {31435657-0000-0010-8000-00AA00389B71} as a media subtype to MEDIATYPE_Video of CyberLink Video Decoder (PDVD10 or PDVD9):
CyberLink Video Decoder (PDVD10) + MKV VC-1: Heavy Stuttering
You can immediately see it with many MKV files with a VC-1 video track. That may be the reason why CyberLink does not use its own decoder for MKV VC-1.
CyberLink VC-1 Loader (MPC).zip 416.6337890625k . file
post #164 of 1608
Excellent, thanks. I'll try this when I am home later.
post #165 of 1608
No worries Eugen. The engineeres have "all" the info they need but can not reproduce the problem. I wonder if win 7 x64 cpmbined with a high res or multi-monitor situation could be the culprit since I am running the same OS and get the same error. Come to think of it the engineeres don't have that bit of info either.... Oh well at least you have arcsoft
post #166 of 1608
Tom
Cyberlink
Tom,
I don't mean to be an ass or cynical but your engineer's hardly have "all" the info they need. Maybe you've never worked tech support but knowing my resolutions and ONE of the video cards in my systems hardly qualifies as trouble shooting. A real trouble shooting routine would require info on my HW, OS, driver versions, etc. This is why I am being cynical - if they are really trying to trouble shoot off of what I briefly posted then there is almost no hope of reolving the issue ever, much less overnight. Nothing personal against you but this is the sort of half baked broken english respons I expect from the cyberlink tech support.
post #167 of 1608
Now I've seen the commercials
post #168 of 1608
Originally Posted by captain_video View Post
Nice to get the info directly from the source so I welcome Tom's presence here. I saw my first 3D display today at a Best Buy in Yuma, AZ (I'm an east coaster out on business) and it looked interesting but nothing I feel I'd have to have. It's a new gadget directed at a niche market but definitely not something I think the mainstream consumer market is ready to embrace en masse.
FWIW, any playback software that supports Blu-Ray but omits support for DTS-HD or Dolby TrueHD is a complete waste of my time and money. Sorry, but you're completely missing the boat here. I feel that support for these audio formats far outweighs support for a format that won't saturate the market for years to come is extremely shortsighted. It appears that you've abandoned a market that is here and now for a pig in a poke.
Until you've changed your product to something I'd actually use I'll stick with TMT for my playback chores. Consider this direct feedback from the end user.
Originally Posted by SamuriHL View Post
Woa woa woa. HUH?? It supports those formats just FINE for blu-ray! The lack of support is in MKV, and they never claimed to support it. We were simply asking and hoping. Let's not misinterpret things here.
That's my bad. I was using my new Motorola Droid for the first time to surf the web and I totally missed the part about lack of HD audio support being restricted to MKV files only. My apologies to Cyberlink.
post #169 of 1608
Problems playing DVDs from hard drive
1 - can not playback directly from Windows Explorer (Video_TS.IFO)
and I notice this message
2- If you play back the internal browser, the screen is framed by the skin
What makes me angry is that with PowerDVD 9 do not have this problem
post #170 of 1608
Playing from VIDEO_TS folder gives no audio. Making an iso from the folder an playing the iso file gives audio!
Playing mkv with dts/ac3 gives no audio.
Free mpc-hc works better!
Using Windows 7 x64 and ATI 5870 with latest drivers. Passes audio through hdmi to Pioneer Receiver.
post #171 of 1608
i get the same with windows 7 32bit,but i have my plasma set to 1080p and pwerdvd will drop it down to its native res which is 1366/768 and then it will play my films if that is any help,and if i leave it at the native res next time i start powerdvd it comes on fine without the message
post #172 of 1608
Tom- you have still not addressed my questions regarding hard drive playback of Blu Ray and DVD disks. There remains confusion in this thread as to any limitations the program places on this kind of playback. I also sent you a PM about it
post #173 of 1608
From my quick testing of it, it was not possible. Only if your movies are ISO's. Could not get DVD/BD in folders to play. Again, limited testing and maybe missed something.
post #174 of 1608
Thanx. But I am running at native res on my monitors. So not sure if that is the issue. It is probabl some stupid software check an engineere put in thinking hey this is a good idea, when its not. It would be nice to know what triggers the error because then we can look for it in our systems.
post #175 of 1608
Hi Tom,
I have just come across this thread as i am looking to find out how to do some bitstreaming on my new HTPC?
I have setup a new HTPC with an MSI 5570 1gb card.
I have installed catalyst 10.2 (and now 10.3a) to try to fix the issue.
I have tried and am still using the EDID fix from another thread.
I am using Win 7 32bit, 3GB ram and liteon Blu-ray player (all files played are official blu-rays not iso's or ripped copies)
Basically what ever I do with powerDVD 10 I cannot get the "3rd Option" to appear to allow me to output pure DTS-HD / Dolby TrueHD.
I have my setup connected to a denon 2309 amp which support and works with both formats (have tested that using HDMI and sony bdp-360 player).
I downloaded a trial of TMT 3 and DTS-HD worked first time, however with out paying for TMT 3 I cannot test Dolby TrueHD (although I would think it would work!!!!). I brought PowerDVD as V 8 came with the Blu-ray drive and for £40 upgrade to v 10 ultra I thought "bargain"
Could you advise as to what the issue may be? Your supported hardware lists 5xxx series as supported but someone on another thread said that on another list it was not down on there.
Cheers
post #176 of 1608
As you have a Denon amp try Tulli's EDID overide thread.
post #177 of 1608
You aren't missing anything here, they have deliberately disabled BDMV folder playback. I am going to stick to TMT 3 (BDMV folder playback is perfectly fine with TMT 3) until Cyberlink engineers sort out BD folder playback issue. Hey Cyberlink, thanks for releasing another crippled version of PDVD and you are loosing customers.
post #178 of 1608
I didn't think i did, but after not being able to"see" WHS or network computers, i really didn't care much about the rest. Funny, it does see the 2 media servers i have in WHS, but of course won't play anything from them. Seems like they trying to make this a more "global" player, with MKV's and such, but why leave one of the more important features out? They have steadily remove features from the software, 7.3 still the best they ever put out. Like you will stick with TMT3. I can care less about the 3D stuff they trying to sell.
post #179 of 1608
BD Folder playback has been disabled for quite a while and it's not new to version 10. I'm not sure what "confusion" there is on that in this thread or what the engineers have to "sort out". I believe that it's working as intended (ie: they don't want you playing back BDs from folders).
post #180 of 1608
Sorry,I feel the first Holy Grail for HTPC is to act like SA BD payer. I bought PDVD10 and it works great with all my discs. I get a great picture with fast load times( faster than most SA players) and bitstream support. If 3D catches on I'll be ready for that as well , player wise.
