If you're bitstreaming (i.e. "without decoding to LPCM") then I don't know why it wouldn't be possible. The problem has been that PowerDVD 9 (and some newer builds of 8, IIRC) didn't decode DTS-HD MA 7.1.
What would be interesting is if this is really true, running a test where it is known which sounds are coming from where. Unfortunately a true DTS-HD 7.1 discrete test is nonexistent (at least for us mere mortals) as far as I know. You can still try with a movie with distinct sounds (my DTS bluray demo disc has one or two clips where this happens), but I'm not sure if a classical music recording does this. Classical multichannel usually only includes ambient sounds in the surrounds.
I have an excellent (but older) Fosgate Preamp that has 7.1 analog in, and an excellent amp (Sunfire signature 200wx7) to drive my Axiom speakers. What I'd LOVE to do is to use my Delta 1010lt in the HTPC and use it's 7.1 analog out, instead of using the onboard SPDIF to the Fosgate. The Fosgate ofcourse does not have HDMI, but that doesn't make it a bad preamp..
