Thank you for answer, so you have H55 intel chipset too ? I want to be sure with this bitstream hd audio it's most important thing for me
I'm planing to buy a Gigabyte GA-H55M-UD2H motherboard and Core i3 530 cpu, I think will enough fast to handle all HD materials.
Is this black screen you have only when you fast forward with HDMI audio output only ? do you try with others video/audio settings in PDVD?
For now I'm using PDVD10 Ultra on Asus Striker Extreme nforce 680i motherboard, E8400, GTX280 and no problem with black screen when fast forwarding on Blu-Ray's, so the conflict is on intel chipset/graphic with PDVD10 looks like.
By the way I want ask is this HTPC what I want to build in future after install PDVD10 with added 3D support will be working with TV with 3D support or will be needed motherboard with HDMI 1.4 output ?
