I am 15 days into the build of a new home theater that will be in a dedicated room that is 20' 10" long by 11' 11" wide (all measurements being drywall to drywall) inclusive of:
-- a separate equipment room (not included in the above dimensions)
-- a sound proof door
-- acoustic fabric wrapping on the all walls and ceiling
-- acoustic paneling/treatment on all walls and ceiling
-- engineered room in that the build / construction methods have been engineered/designed to keep all outside sounds from coming in and all sound from escaping...even gone as far as redoing the HVAC inclusive of the the use of "mufflers" for both the return and supply
-- Stewart AT FireHawk 90" x 51" constant width screen with masking (although I watch movies in total darkness I do often have friends over to watch sports with low level lighting thus the decision to go with the FireHawk material and CIW)
-- Too many other things to mention now but can / will be listed later
That said, to the extent that there is interest I thought I would post some pictures every days noting that this first batch of pictures is from yesterday which was DAY 15 of the build...
With that, I hope that you enjoy the pictures and let me know what you think...
The above image shows the construction method for this wall includes Roxul sound proofing which will then have installed on it using isolation clips to make the wall resilient a layer of engineered plywood, a layer of green glue and then a layer of engineered drywall
The above image shows the top right front corner/soffit which follows a familiar pattern for the rest of the room (i.e. other than the above wall) in that every nook and cranny is filled with Roxul which is then covered with drywall, a layer of green glue and a layer of drywall...
The above image looks from the front of the room into the back of the room...what you see is the framing for the back wall of the theater room as well as the roxul filled back wall of the equipment room...the HVAC is still being worked on and you can see in the bottom left corner the custom made return which is treated with acoustic material inside...what is not shown is the muffler that is part of this system...
Good luck, half the fun is building the room!
Yawzas. You arent messing around are you?
