Originally Posted by
AK1997
Does it output the audio from all the sources though (HDMI, component, etc.)? Also is the audio lagging behind the visuals?
Yes it outputs from all the sources.
I can't really tell that it's lagging behind the visuals, but it probably is. The only reason I can detect the input lag is because I have my PC outputting audio through HDMI to the TV, but I also have my headphones plugged in directly to my soundcard. If I listen to something on the PC, the sound comes through the headphones before it comes through the speakers.
Like I said earlier though, this is an issue with every HDTV I've ever tried. At least on my Sharp the audio out from the TV was lagless. Sadly it isn't the case here. I expect the issue will only ever show when playing rhythm games (and I'm extremely picky about fast audio response in rhythm games).
python26
First time posting. Thought I'd share my settings for my 40EX401. This is using the DVE hd bd on my ps3. The environment I view in is either at day with all my windows closed off or at night (with or without the light on).
Scene: General
Mode: Custom
Backlight: Min
Picture: 94
Brightness: 52
Color: 48
Hue: 0
Color Temperature: Warm 2
Sharpness: Min
Power Saving is on high (which seems to automatically turn the backlight to it's lowest possible value).
All other controls like cinemotion, ambient sensor or contrast enhancer are turned off and white balance is left at default.
Not the most accurate colors, but the black levels are outstanding.
Yeah this TV does have outstanding blacks if you can use it with a low backlight.
As for the color accuracy, I suggesting switching to Warm 1. It's this TV's neutral setting, from the calibration I've done with DVE's color filters. Both green and blue are very accurate, though the TV pushes more red than it should. The accuracy is actually very good considering this is an LCD.
