Originally Posted by limpingpony
I made a thread about this before I saw this thread but I figure you guys could help me. I am really trying to decide between the KDL32EX500 and the KDL-40EX400. Basically I am trying to decide between the 60hz 40" or the 120hz 32". I will be using this tv for PS3 gaming, blue-ray usage, and tv watching. I have been doing a lot of research on the advantages of 120hz over 60hz for gaming and blue ray but I have been seeing lots of contradicting information. I primarily want to know how much different the blue-rays will look in the 24fps modes. The tv will be in a fairly small apartment so 32" will basically be big enough, but moving to 40" could only help, unless 60hz is a noticeable disadvantage compared to 120hz. Are there any other differences in these sets? Any input would be helpful, this is a pretty large purchase purchase for me so I don't want to regret it.
Take my advice with a grain of salt because I'm definitely not the foremost expert on this forum. But I believe your decision is a bit tricky. I understand 120Hz to not be very noticeable on a smaller display like a 32". That observation, combined with the argument that an additional 8" in display size will "slap you in the face" much more strongly than 120Hz will, lead me to suggest that you chose the larger display for the same price.
With that said, until we can conclude just how different the EX400 and EX500 are in terms of PQ, I think your decision is still up in the air. If it turns out that the EX500 has noticeably better PQ then I'm inclined to go with the 32" EX500 so long as that size is sufficient for your space. If it turns out that the PQ difference is negligible, then I'd go for the 40" EX400 and dismiss the other minor differences of 120Hz and swivel base.
To add a final bit of difficulty to your decision, I don't believe the 32" EX500 is available at Costco (EX501). The fact that the 40EX401 is available at Costco (with 3-years of warranty, or 4-years if you pay with AMEX) and is void of the silver bezel treatment may be enough reason to look towards the EX401 even if the PQ is slightly inferior.
