AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony KDL 32EX400 40EX400 46EX400 EX401
Official Sony KDL 32EX400 40EX400 46EX400 EX401 - Page 25
post #721 of 769
Alright, I updated my calibrated post with new settings which get the greyscale pretty close and color more accurate. I used an i1DisplayLT + ColorHCFR.
post #722 of 769
I could not find your calibration settings post. Mind you I'm using the Avs app for iPhone and the search function is broken. Could someone link to it?
post #723 of 769
It's in my signature, I'll go ahead and link it for you.
http://www.avsforum.com/avs-vb/showt...3#post19058823
post #724 of 769
Hey fairchild, i was thinking about your panny after i saw your name pop on here, you've had it a few months now, have any of the stock parts pooped yet? My TV has turned 1 year this feb and is still going strong on the replacement parts. It will be 1 year from service in July.
Hope all is going well for you still.
post #725 of 769
I've had it for about 6 months now, and yeah it's still going strong. It's got over 2k hours last I checked (probably closer to 2200-2500 hours now).
I also calibrated it and it's picture is looking great. It had been running a bit warm (was sitting at around 5500k with the stock Warm temperature).
post #726 of 769
I have a KDL-40EX400 and it has no audio thru hdmi. It has video but no audio. Any idea what might have been the problem?
post #727 of 769
Probably just a setting in your AVR. What exactly is your setup?
post #728 of 769
It is a dish network 211 receiver. It works ok in other TV, the problem is with the Sony.
post #729 of 769
anyone post calibration settings for play ps3 games on limited rgb
post #730 of 769
I own a 40ex400. I lovely set. Blacks are deep, virtually no input lag and and teeny bit of motion blur. You'd really have to stop and try an notice the motion blur. My only con is that the set doesn't support dts feedthrough from hdmi to optical out officially. It works perfectly but from time to time a warning sign saying invalid sign pops up. You get rid of it by switching inputs. Anywho down to business. I tweak and calibrate my set everyday. I swear its an ocd. All my settings are different depends on what I'm doing. Bare with me. These are my settings...
For ps3 with full rgb for playing games using custom setting
Backlight=max. Advanced settings
Contrast=86. Contrast enhanser=off
Brightness=58. Black corrector=off
Color=54. Gamma=0
Hue=0. Clear white=high
Color temp=warm1. Live color=off
Sharpness=2
All noise reduction is off
Cinemotion=off
Ambient sensor=on
Ps3 dvd settings using y pb/cb pr/cr instead of rgb @1080p on standard setting
Picture=88. Contrast enhancer=low
Brightness=54. Black corrector=low
Color=46. Clear white=off
Hue=0. Live color=low
Color temp=warm2
Sharpness=0
No noise reduction
Cinemotion=auto
Ambient sensor=on
Ps3 blu ray settings using y pb/cb pr/cr @1080/24p on theater setting
Backlight=8. Advanced settings
Picture=95. These are automatically controlled in theater mode
Brightness=34
Color=46
Hue=0
Color temp=warm1
Sharpness=2
Noise reduction is off
Cinemotion=auto
Ambient sensor=on
Hop you guys enjoy these. Like I said I'm constantly tweaking and playing with the settings but these are the best I've come up with yet.
post #731 of 769
hey you dont have calibration of ex400 for play ps3 or xbox..
post #732 of 769
Color=54. Gamma=0
Sharpness=2
Cinemotion=off
Ambient sensor=on
Color temp=warm2
Sharpness=0
No noise reduction
Cinemotion=auto
Ambient sensor=on
Brightness=34
Color=46
Hue=0
Color temp=warm1
Sharpness=2
Cinemotion=auto
Ambient sensor=on
hey you play on limited rgb or rgb full on ps3
post #733 of 769
Oh good! glad to hear it. Mine has been rock solid since the stock board was replaced and I got it connected via the ups surge protection. I calibrated mine a while ago from a panasonic specific thread, since I don't have any hardware devices and did tweaks from that to my lighting and it looks great!
Thanks again for the sony settings for white balance you posted a while back. I tried those and the sony looks much more like the plasma now in terms of color accuracy.
P.S. My panny has turned a year old this past feb, and it will be 1 year from service this July.
The sony will also be a year in July, Keeping my fingers crossed that I will not be one of the ones where the panel dies after a year to 14 months of use. I've read numerous reviews about sony tvs of this happening this model and a couple other models too.
post #734 of 769
I use full rgb range. I've calibrated using both and full just looks better and more vivid. It feels like a wider range of colors are displayed.
post #735 of 769
i have 1 more question i use standard and calibrate with avchd disc brightness 54 are good not lost details my question is on brightness on 54 look little washed how get blacks more black whit brightness at 54 .. gammma or black correction??
post #736 of 769
what's scene mode is the best for playing videogames and who is already calibrated?
post #737 of 769
for a while I've been noticing something. It looks like vertical lines on the screen. I was thinking it could be pixelation but it's not just when I'm watching cable. When I use my ps3 to play a movie i get the same thing. Does anyone think they might know what i'm talking about? The It's a 40in in my bedroom. My room is small so i'm sitting pretty close to it. I was also thinking that maybe it's motion blur as i don't know exactly what that looks like. If the picture is still that you can't really notice it but once the camera moves you can tell. I also though that it was a stain from cleaning but i don't think it is anymore. I bought this windex electronics stuff that works pretty good.
post #738 of 769
macro shots from 40EX401
looks like its using a Samsung Panel? http://72.9.159.100/avs-vb/showpost....&postcount=793 reminiscent of the Samsung LN40B500 panel layout and some commented on that thread it wasn't proper 1080p because of the way the pixel formations were unequal in size
however text is clear and easily readable on 40EX401, black levels and motion is good
chroma test
post #739 of 769
its for sure using a Samsung Panel ltyz 400hm01
the service menu codes from the ex500 thread work on this tv http://www.avsforum.com/avs-vb/showt...227927&page=76
method 1
With the TV turned on, input this code:
Left > Right > Muting > Center + > Muting > Menu
method 2
With the TV off, input this code quickly:
display > 5 > + volume > power
post #740 of 769
I did some searching and I think that the lines I'm seeing is vertical binding. I guess It's a defect so that sucks. They're barely visible but they're definitely there.
post #741 of 769
new firmware update for these line of TV's
http://esupport.sony.com/CA/perl/swu...=6829&os_id=25
Benefits provided by previous updates and included in version 1.514:
  • Resolves an issue where color may be incorrect when using an HDMI® connection.
  • Resolves an issue where some Cisco cable boxes may stop responding when the TV is turned on.
  • Resolves an issue where the picture may not be displayed when using a Sony® BDP-S570 Blu-ray Discâ„¢ player connected by HDMI and using one-touch play.
  • Allows for the power-on chime sound coming through the TV speakers (not through the Optical Out) to be turned off in the Setup Menu.
edit: Flashed successfully - got worried during flashing process as it took longer than i was expecting
post #742 of 769
  • Resolves an issue where the picture may not be displayed when using a Sony® BDP-S570 Blu-ray Disc player connected by HDMI and using one-touch play.
Thanks for the heads up. Personally I'm going to pass as the only change from the last update is:
Increases the maximum number of channel presets for some regional broadcasters.
And this doesn't affect me as I use a STB cable box.
post #743 of 769
new firmware update [1.514] for these line of TV's
It appears that thus far, few have taken the leap, in either the EX400 or 500 camp. Not a surprise, considering there is no notification other than word of mouth, and these sets have few outstanding bugs to speak of.
Can you comment on what it actually did in terms of tangible changes?
I interpret the change to mean that it increased the number of Favorites slots. If so, how did they cram more slots onto the screen? Smaller font? The current list already occupies most of the vertical resolution.
post #744 of 769
haven't noticed any changes, tv is working good as usual
post #745 of 769
Just bought this tv (actually thought I was getting a BX420) and love it.
I have TW cable and use the RF coax for channels. I receive 1-90 (analog 480i) along with a good bit of digital clearqam stations. Very happy.
I also own a Sony STR-DH700, and am wondering if the remote for the TV will control that A/V unit, or do I need to use a Universal remote? (I own an old Sony RM-VL600 Learning remote)
post #746 of 769
Originally Posted by greyest View Post
I used to play in FullRGB exactly because of aforementioned reason (better color saturation) until I realized that I could set exactly same colour saturation in standard RGB mode.
Set it as you like (i.e. rise it up in the TV's settings) and switch back to standard RGB in PS3's settings, Full RGB really makes it hard to discern details in dark places.
How do you set the RGB on the tv settings? Is that the white balance? What do you set it to?
post #747 of 769
You can't, you have to change them on the source device (blu-ray player, receiver, video card, ps3/xbox, etc)
post #748 of 769
Improvements over version 1.512:
that is the only new improvement of 1.514. all of the other improvements occurred prior to 1.514
post #749 of 769
What did they mean "rise it up in tv settings"?
post #750 of 769
HK_9, I think they meant settings like brightness/contrast/color that you can change in the TV.
