AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › 965BE , Ubuntu 9.10 64bit - CPU performance problem
post #1 of 3
I've HTPC running 965BE with Gigabyte UD2H micoATX am3 board, with 4G DDR3. Everything works fine with the ATI Catalyst drivers with ONLY one gripe.
Whenever I play some flash/youtube videos using Firefox OR play some streaming video using VLC player, there is a heavy CPU usage. The fan starts revving @ high speed that is very very audible. All other times (like download, mp3 playback or gimp) the CPU usage is pretty ok. (Almost 60% idle).
Considering flash performance in Linux is sub-par, what are the tweaks / tuning I can do? (I did use ondemand script thats being used online @ many places).
Feel free to ask me qns, if you need some more hardware/logs info.
Thanks a bunch in advance!
post #2 of 3
Other than verifying that you're using the latest Flash driver (10,0,45,2), I doubt there's much you can do.
post #3 of 3
If the cpu fan noise is the issue, replace the stock cooler with one that supports a larger fan. I use TR2-R1's on all mine. If your MB won't control standard 3 pin fans, replace the fan with a PWM fan. I don't recall the fan speed ever going over about 800rpm using fan control on the stock fan. It's max speed is about 1500rpm.
  Back to Forum: HTPC - Linux Chat
