Originally Posted by
hydrogin
I'm guessing more seed electrons will make it easier/quicker to increase current across the subpixel later on?
Yes, well more accurately, the presence of seed electrons reduces the discharge delay. Ionization of the gas becomes easier (less voltage required) and quicker (less delay between voltage application and ionization).
hydrogin
But maybe this will also create more electrons that can be excited to create phosphor-knocking UV photons In which case the black level might not be as low as it would have been had a shorter initialization (and slower "turn on") been used?
The seed electrons are created via a secondary electron effect. The top two electrodes are coated in MgO which has a very high secondary electron coefficient in Xenon/Neon. When the cell is discharged, high energy ions impact the MgO and electrons are ejected into the discharge space. The black level is visible because during the initialization step the gas is discharged (ionized) creating UV radiation. The strength of this discharge determines the brightness of the black level.
Now, if priming (seed electrons) is very efficient and long lasting then there is less need to prime and thus the black level can be reduced by lowering the voltage or by reducing the number of initialization steps per frame.
hydrogin
I do remember the PWM signal in the sustain phase is responsible for establishing grey level, but that must be on top of a DC level established by the seed electrons?
Yes, but if there is no image data sent to a pixel, there is no PWM, but the pixel still must undergo initialization to keep up the priming. This is why you see a black level MLL no matter what is on the screen.
hydrogin
Initialization - Apply voltages across subpixel to bleed out charge. Then apply voltages to inject "seed" electrons and produce +/- charges on opposite walls. Gas is now a low-energy plasma with ionized atoms and electrons? Or perhaps the gas isn't a plasma yet, we've only managed to inject/tunnel some electrons across the dielectric barriers?
Address - Increase voltages and current across subpixel, gas is presently a plasma, introduce more carriers into the plasma until electrons jump their valence shells. Electrons now produce UV photons upon returning to lower energy states. UV photons strike phosphors and emit visible photons.
Sustain - Continue applying voltage (at lower level?) to continue electron excitation. I'm not sure why there are multiple sustain cycles within a single subfield cycle. Could this be some sort of power-saving step given that glowing has a some kind of inertia (glows for awhile, then decays)?
The initialization is usually a ramp pulse that creates a small discharge (ionization) in the townsend region. This charges/discharges the dielectrics and at the same time generates secondary electrons from MgO as mentioned above.
The Address step selectively discharges (ionizes) to create enough wall charge for the sustain step.
The sustain step applies a AC pulse train because each pulse phase creates a discharge followed by quenching and then reverses polarity and repeats. The longer the AC pulse is applied the more discharges occur and the brighter the light emitted.
hydrogin
Finally, I was curious in your other thread, you say as the panel ages, the voltage needed to initialize must increase. Is this due to some fatiguing mechanism in the dielectric?
They do not explain it in the patent. However, I speculate that the MgO material is sputtered and deposited onto the phosphor in a form that is less electrically active (lower secondary electron efficiency). This will increase the voltage required to discharge the gas, especially in the initialization step.
BTW, I love talking about this stuff so thanks
Cheers
