The Onkyo 608 is DRASTICALLY upgraded than the 607
SKIP TO PAGE 17 WHEN OWNERS FINALLY GOT THEIR UNITS
HERES A VIDEO OF THIS UNIT: http://www.youtube.com/watch?v=Rsrop2VTs5E
Onkyo TX-SR608 from site: http://www.us.onkyo.com/model.cfm?m=...s=Receiver&p=i
AUDYSSEY SETUP TIPS!!! http://www.avsforum.com/avs-vb/showt...5#post14456895
Read below for differences between the 608, 508 & 707
NEW for SR608 vs SR607
100W/CH @ 8 Ohms vs 90W
HDMI 1.4a 3D Ready (Backwards compatible) vs 1.3a
Faroudja DCDi Cinema™ 1080p upscaling vs Faroudja DCDi Edge™ 1080i upscaling
THX Select2 Plus Certification vs No THX Certification
Weight 25.4 lbs vs 23.8 lbs
Burr-Brown DACs vs Not Burr-Brown
Power consumption 6.3 A vs 5.5 A
OSD Out: Advanced Home GUI vs via HDMI
New PC input
New 4 DSP Gaming Modes: Rock, Sports, Action, and Role Playing
New lossless Dolby and DTS codecs
New overlaid onscreen graphical display (Watch TV while using Menu)
New Three-stage inverted Darlington circuitry and jitter-cleaning technology
New Audyssey DSX
Upgrades from 508:
PC input
THX certification
1080p upconversion using Faroudja DCDi cinema
100w/ch vs 80w/ch
2 more HDMI inputs
Solid aluminum front
25 lbs vs 19 lbs
Audyssey DSX
Power consumption 6.3A vs 3.9A
Downgrades vs 707
Audyssey Mult Eq
Pre-amp out for separate power amp
DTS Surround Sensation Speaker / Headphone
a. All discrete circuitry
b. RS-232
c. IR input
d. 12v trigger
e. Learning & Activity based remote
27.8 lbs vs 25.4 lbs
608 uses 6.3A vs 5.9A
Heres what a-e do:
a. reduces noise I believe
b. allows for control via serial ports (can do this over ethernet if the receiver has it like my 1007, very nice)
c. so you don't need to stick a blaster to the front of the unit, keeps it clean
d. allows you to turn on another device that allows 12v trigger, amps, motorized projector screens, etc
e. basically has macros and can learn commands from other ir remotes
Ways to shut off Video Processing
Thanks PS24eva) UPDATE 9-9-10
setup -> 1. Source Setup -> Picture Adjust
Game Mode Off
Wide Mode Auto
Picture Mode Custom
Film Mode Video
Noise Reduction Off
Then use the VCR & Return OSD disable. On the unit itself, press VCR first, then Return (second after or so), you will see something that looks like:
Vprocessor: USE
While STILL holding VCR &return, use the D-pad to change to "Skip"
New PC input
New Audyssey DSX
Upgrades from 508:
PC input
THX certification
100w/ch vs 80w/ch
2 more HDMI inputs
25 lbs vs 19 lbs
Audyssey DSX
Downgrades vs 707
Audyssey Mult Eq
b. RS-232
c. IR input
d. 12v trigger
Heres what a-e do:
Thanks PS24eva) UPDATE 9-9-10setup -> 1. Source Setup -> Picture Adjust
Game Mode Off
Wide Mode Auto
Picture Mode Custom
Film Mode Video
Noise Reduction Off
Vprocessor: USE
