AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Onkyo TX-SR608 Thread (No Price Talk)
The "Official" Onkyo TX-SR608 Thread (No Price Talk) - Page 129
post #3841 of 5217
Originally Posted by Donmichaelo View Post
JCTh and all experts:
Activating the HDMI control in "Hardware" I got the image with the Onkyo OFF but no SOUND...any clue?
DonMich
Hi Don, turn HDMI Control and Audio Tv Out to "ON".
post #3842 of 5217
Originally Posted by Mr. Grundle View Post
Yes the switch on the xbox is on hdtv.
Component cables are correctly connected to green, blue, and red.
For audio i am using red & white which is currently connected to TV/CD audio input. I'm not sure if that is correct either I've been more focused on getting a picture.
Thanks for your reply.
Go into Xbox 360 video menu and try a lower resolution setting.
post #3843 of 5217
Thanks JChin, being 1:30 am here in Dominican Republic, I will try tomorrow.
(I have to take advantage of this marvelous temperature 17 degree, very unusual in the Caribbean area and have a good dream!! )
Thanks again, I have to remember to turn the TV volume up too!!
Cheers
DonMich
post #3844 of 5217
Cheers
DonMich
11:51 pm here in Texas, report back with your result, good luck.
post #3845 of 5217
Greetings,
I've had Custom Names set up for each input for a while. Suddenly the reciever has reverted to showing the default input, and the listening mode that I am set to, so instead of Roku, I get CBL T--D.
When I go into the menu, the custom name still shows. Any suggestions on how to fix this?
Thanks for any help!
David
post #3846 of 5217
Ok...we got video and sound now...BUT video is coming through the TV speakers, the external audio speaker is muted.
Is there any way that we can get the external speakers sound sounding with the Onkyo off?
Why we can get the video thru the HDMI but not the sound? Aren't both signal come together thru the HDMI?
Thanks again!
DonMich
post #3847 of 5217
So After getting my 608, new energy speakers, polk sub and sammy tv all hooked up for less than a week, my PS3 Fat dies. red blinking light. lovely.
So yesterday I picked up a PS3 Slim, and changed the appropriate settings to get bitstream working. I'm not sure what equivalent listening mode to set it on now though. I'll try to explain..
When my PS3 Fat was doing the decoding and sending via pcm, I believe the onkyo was set to MultiChannel as the listening mode, which sounded great. I experimented with the different THX and other listening modes but liked the straigh multichannel mode with no other enhancements.
Now that the PS3 Slim is bitstreaming (and its definitely working, got the whole DTS-HS lights and all), I'm not sure what the equivalent non-processed mode should be. It seems there is no "regular" mode, and that I have to pick one of the enhanced modes. The only one that seems like it would make sense is "direct", but that mode sounds terrible and is extremely quiet, nothing like the PS3 Fat doing the decoding and sending PCM to the MultiChannel setting. The most similar setting from a sound quality and volume perspective is All Channel Stereo, but isn't that negating the surround mix to begin with?
Anyone else bitstreaming to the 608 with PS3 Slim? What listening modes do you like for action movies and bluray concerts?
Also somewhat unrelated, but when using netflix on the PS3, how is bitstreaming working for that, and what listening modes are you using for that?
post #3848 of 5217
Originally Posted by tgr131 View Post
Greetings,
David
From what I can see you just need to press the Display button on the remote until it says Roku and then the volume, is that what you want?
post #3849 of 5217
Does anyone know if Onkyo will or can do anything about the Video processing on the 608, with regards to the stutter and the fact that you have to turn off the OSD.
Is it safe to assume these bugs are here to stay and just needed to be accepted?
post #3850 of 5217
Hello everyone,
I was playing around with the RIHD connectivity on the SR608. Can someone educate me on how RIHD works between SR608 and PS3? I toggled between settings, and I only managed to turn on the "thru" setting for PS3.
1. Are there any other benefits (apart from "thru" mode when receiver is off) of the RIHD?
2. When I have the "thru" mode on, my SR608 never goes into standby (the red light). It's always on "thru mode" (yellow light). Is this normal? I thought the yellow light only comes on when your input source is activated, but the receiver is on standby, thus activating "thru mode".
post #3851 of 5217
If I wanted to send 720p @ 120Hz from my HTPC to my projector, would I have to disable video processing? Right now when I set it to 120Hz on the HTPC I get tons of artifacts. I haven't ruled out the nvidia chipset either, to be honest, especially being in a non-native resolution.
post #3852 of 5217
The vast majority of users experience no issues what so ever .. I have had mine since the week it came out, I use the OSD, my video is brilliant, my audio is brilliant .. as we've mentioned on the thread many times, no AVR will play nice with each and every component that's available .. in this case, it's a matter of proper set up more than anything else ..
post #3853 of 5217
The problem for me is that having the video processor on causes ghosting on my Sky TV unless I turn it down to game mode, the manual says that game mode will degrade the picture quality so I don't like the sound of that.
Also there is the 24p stutter bug, i'm not currently but soon will be using my boxee box at 24p once a bug has been sorted. Are you saying that the 24P bug doesn't happen for everyone?
It seems a shame that it still applies processing when set to through mode
post #3854 of 5217
In order to have an OSD, any AVR must do some degree of minor processing .. it's the nature of the beast ..
post #3855 of 5217
I agree it has to mess with the signal to make the OSD, i'm fine with that but when set to through, I don't want it to process the video other than making the OSD. I also don't want stutter in my 24p content which is 99% of my content.
Do you play 24p content?
post #3856 of 5217
I am VERY pleased with Onkyo repair service. No hassles, sent mine to Pinnacle Solutions Services in Haverhill MA & it comes back fantastic.
post #3857 of 5217
20 days, not bad
post #3858 of 5217
I got my receiver today. I have a 5.1 setup with my rear speakers behind our couch against the wall about 6ft directly behind us. I hooked the rears to the surround back ports but only one speaker is detected during setup. Should I be connecting them to the surround ports and not the surround back ports?
post #3859 of 5217
Hi Stryker412, yes for 5.1 setup connect the two to Surround not Surround Back.
post #3860 of 5217
Wow thanks for the quick response!
post #3861 of 5217
I finished setting up the speakers but am not getting any video. I have 4 HDMI devices and the monitor out going to my TV. Can't figure out what I am doing wrong.
post #3862 of 5217
Anyone figure out how to kill the relay clicking?
I know it's searching for signal. But wtf?!?
Actually I got it
http://www.avsforum.com/avs-vb/showt...3#post19738043
What's the best 5.1 surround option for 2.1 channel? or for default 5.1 channel for that matter.
post #3863 of 5217
I am pretty sure you can't, that's why people turned the OSD off.
You can only get one or the other
post #3864 of 5217
Are you getting a setup menu? If not make sure the correct HDMI input is selected on the tv (got to ask just to make sure ).
post #3865 of 5217
SHUTTER is a DISPLAY problem
post #3866 of 5217
Yes I get the menu fine which is why I just think I missed a setting somewhere.
post #3867 of 5217
The PORT Labeled MONITOR OUT is the WRONG port.
You need to be using HDMI OUT next to HDMI IN #1
Look at Diagram on Page 17 of the Manual
post #3868 of 5217
I am using that port. Like I said I get the setup menu but then it just goes to a blue screen once I leave the menu.
post #3869 of 5217
Your previous posting said MONITOR OUT
I believe if you just walk though Page 38 & 39 of the manual
you should get Video out to the HDMI Port, as long as you
are seeing the 608 setup menu on your Display Device.
post #3870 of 5217
Make sure you have your inputs assigned correctly.
Setup:
1. Input/Output Assign > 2. HDMI Input;
