AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Onkyo TX-SR608 Thread (No Price Talk)
The "Official" Onkyo TX-SR608 Thread (No Price Talk) - Page 169
post #5041 of 5217
Actually that was part of my question I forgot to add
What optimizations does the latest firmware provide?
post #5042 of 5217
If it provided any you would be able to download it.
It was a Temporary BUG Work Around for Satellite 3D boxes.
post #5043 of 5217
Ah! Good call. Good call.
post #5044 of 5217
quick question,so what exactly does "direct mode" do? does it turn off the internal dac,so the dac of the cd player can be utilized? thanks
post #5045 of 5217
Direct mode doesn't apply any matrixing or mixing to the sound. If it gets 2-channel audio, it plays 2-channel. If it gets 5.1, it plays 5.1. AFAIK it still applies effects and Audyssey. Pure Audio or Pure Direct does not apply anything at all to the signal.
post #5046 of 5217
thanks for clearing that up,was thinking of buying my "last cd player",but if i'm not going to get better sound from the players dacs into the reciever it would probably be pointless?
post #5047 of 5217
The chances you'd be able to notice the difference between your receiver's DAC and a $20,000 DAC are pretty much zero.
post #5048 of 5217
Then why is there still a market for $20,000 DACs?
post #5049 of 5217
Because people want to believe.
And the manufacturers of the $20,000 DACs assure them that they're infinitely better.
post #5050 of 5217
thanks guys for the info,emotiva has a nice sale going on,that cd player has caught my eye
post #5051 of 5217
Coming up on one year since I got the 608. Still very happy with it. I still feel like I got an above average receiver for an excellent price. And of course I must give high praise to all the folks here that made set up and minor blips much easier to deal with. Love my first Onkyo!
post #5052 of 5217
Tried using the updated Netflix app on 360 and the sound is VERY low. I normally game with the volume at 35, but I need to turn it up to 45-50 in order to hear anything on Netflix. Any ideas?
post #5053 of 5217
Hey guys, I hear this unit is similar to the RC260. Anyway, on this unit, say I am going with all my devices into the AVR, and everything going out from the HDMI OUT to the TV.
Could I watch one video input (cable TV with component cables) and switch audio sources while watching the same video source? I would like to be able to watch sports while listening to music.
Basically I'm just asking if you can switch your audio source separately while watching the same source.
I found the manual online but so far it isn't a whole lot of help. Are you able to assign video inputs multiple times? Say, I would set up one preset with cable box video and audio, and one with cable box video and different audio (iPod, laptop, any analog signal)?
I've only dealt with old-fashioned audio receivers with old analog (yellow) video inputs. Until now I've just been going into the TV with HDMI directly with no need for a receiver.
I know I could just go from the cable box into the TV, and then have the audio go to the receiver, but I was hoping to have EVERYTHING going from the HDMI OUT to the TV.
BTW I don't actually have an AVR yet. I don't want to buy one specifically for upconverting everything to one HDMI OUT if it's not going to let me switch audio inputs anyway.
Thanks for any help! Sorry if it's not making sense.
post #5054 of 5217
here I can answer my own question. Apparently you can just use an Audio Only input such as TV/CD. For anyone else wondering, this is from the RC260 manual...
Recording Separate AV Sources
Here you can record audio and video from completely
separate sources, allowing you to overdub audio onto your
video recordings. This function takes advantage of the fact
that when an audio-only input source (TV/CD) is selected,
the video input source remains unchanged.
post #5055 of 5217
Sound normal compared to what my volume range is. Watching TV SD channel is around -35 to -45. HD -20 to -30. Blu-rays -20 to -25. Not sure what the volume is on netflix from the bluray player.
post #5056 of 5217
At the risk of link-dropping, see this for volume levels:
http://www.thx.com/consumer/thx-tech...ference-level/
IE since the 608 is THX certified, in a perfect world after having run the Audyssey setup, if you set it at 0 you should hear reference levels. Of course the volume scale has to be set at relative instead of absolute.
Movies are supposed to be normal during dialog scenes and loud during action scenes, ie dynamic range in action.
Unfortunately for regular TV this allows for commercials that really are louder than the program.
post #5057 of 5217
I have the following setup:
Onkyo TX-SR608, Sony BDP-BX38 BluRay player, and LG 55LV4400 LED LCD TV
Everything except the TV is in rack in the kitchen pantry. When the house was built, 2 coax lines were run from the pantry to the wall were the tv sits.
House was build 20 years ago.
I am now trying to get this setup for HDMI, for BluRay playback and upgrading to HD on FIOS.
The path from pantry to TV is about 35 feet. I have a 40 foot 22 AWG HDMI cable, the unpowered HDMI extender (part 2849, usese MAX3814), and a 6 foot 24 AWG HDMI cable, all from monoprice.
I also have a 3 foot 24 AWG HDMI cable connecting the BluRay to the Onkyo.
If I run the 40 HDMI cable directly from the BluRay player, to the extender, to the 6 foot cable, and into the LG LCD, it works great, up to 1080P. (TV reports 1080P/24Hz).
If I run the same cable setup from the Onkyo, I can see the upconverted signal from FIOS STB, and VCR just fine, and the TV reports getting 1080P/60Hz.
When I try to play BluRay thru the Onkyo, I can hear the audio cutting in and out, and see the HDMI indicator on the Onky flashing. The LG will show a purple, green or blue screen, and will drop to 480P. I will get audio back after a few seconds.
If I move the TV next to the rack, and run the 6 footer directly from the Onkyo to the TV, everything works just fine.
Any ideas? I have already tried turning off video processing on the Onkyo, and setting monitor out to through.
post #5058 of 5217
Why the extender especially since its not powered?
I am running a 50ft HDMI from Monoprice and don't have any issues. I have a HDMI from bluray to Onkyo to TV.
I don't know why your audio would be cutting out but the data used on bluray is probably double what FIOS would be sending to the tv so I could definitely see issues coming up there if there were any bandwidth issues.
post #5059 of 5217
the extender pulls power from the tv via the hdmi cable. I get no signal at all without the extender.
The audio is cutting out as the HDMI chain attempts to handshake everything again.
post #5060 of 5217
Bought this receiver in March '11. Was very, very, very pleased with it until we started getting odd HDMI glitches in September. Sometimes we would skip forward on a DVR recording and suddenly we'd be hit with white noise out of the system at 120dB. The only option to stop it was to turn the damned thing off and restart it.
That happened a couple times. I thought it was an issue with handshake between the UVerse box and the Onkyo. No big deal so long as it wasn't a frequent occurrence.
Then the HDMI started getting flakey everywhere. First the DVD HDMI port wouldn't function at all, but I worked around that by moving the BR to another HDMI input. Then the UVerse HDMI got flakey and wouldn't work. But I worked around that.
Then the whole damned HDMI board went caput. Nothing would process through HDMI whatsoever. 8 months of having the 608 and it already had the HDMI board die. Ridiculous.
It's been in the shop since Nov 18 with no response from Onkyo on availability of that HDMI board. The shop guy tells me this is common with year-old models and that the board is likely out of production, at which point I will have to fight Onkyo for a replacement.
I know this has happened to quite a few folks on here. What's the plan of attack? Should I push for an NR609 or something else? I don't want to deal with HDMI bs again if I can avoid it. I'm almost to the point of dropping the Onkyo brand and moving to a Yamaha Aventage or Pioneer Elite.
post #5061 of 5217
Can someone clarify speaker layout for me? Right now I have;
Fronts - Monitor 60
Surrounds, rear surrounds, center and Sub - Boston Acoustics MCS 95
When I do the Audessy test it indicates I could also add front highs, or front wides? I thought my current set-up was the max speaker positions the 608 could handle? I thought I had to choose only one set from front high, front wide or rear surrounds? Can someone clarify?
I have a pair of Monitor30 speakers on the way, would I be best putting them as surrounds or rears? Depending on the question above, then I could move the MCS95 up front high..?
post #5062 of 5217
Fronts - Monitor 60
On the first round or pass of Audessy calibration, it checks all the possibilties, then determines your configuration. On the second and third round/pass, it only checks what you have set up for speakers.
From the looks of your set up, you have the max for the 608 which is 7.1
post #5063 of 5217
Well guys, I am fortunate enough to get a second hand 12" JBL powered subwoofer from my father to hook it up as a second to this unit. I'm very excited, but haven't even ran the cables yet! Originally, there is a 10" Paradigm (?) sub hooked up by the HT company. Does it matter if that remains my primary since the JBL is bigger in size? Are there any precautions/recommendations I should consider? Really want to get this cranking and challenge the structural integrity of my house
post #5064 of 5217
The same signal is output from each subwoofer pre-out jack.
post #5065 of 5217
Received the onkyo dock for christmas. Very happy with the quality, but man is that thing persnickity! Very touchy, almost acts like a moody person. Happy and alert one time, then tired and sluggish the next. Definately will need to spend some time tinkering with it.
post #5066 of 5217
I've got a UP-A1 and have it connected to my SR608 and I would like to be able to use the dock as the audio source, but use one of the hdmi inputs for the video source. Is there a way to accomplish that?
post #5067 of 5217
I apparently have the same problem with the 608. The HDMI out board has given up and I get the blue "no signal" screen regardless of hdmi device, input, or wiring. It's still under warranty, but the regional tech who is looking at it indicated this is a common problem. They are replacing it with a better board.
post #5068 of 5217
Hi,
I have no idea what the Audio --> Audio Selector option does. In it I see Analog or OPT as options. I'm running an external DAC through this particular input so is there a 'preferred' setting for that?
My DAC is connected to my Onkyo via RCA cables so I'm not quite sure I understand why OPT is even an option?
CG
post #5069 of 5217
Originally Posted by cg27288 View Post
Hi,
CG
Does this unit have true analog passthrough?, meaning by hooking up an external dac that it's not being reprocessed by the onkyo's dacs? What input on the onkyo do you have your dac hooked up to? I've asked a similar question also, so i'm curoius about this, are you sure your dac is far superior than the onkyo's ?
post #5070 of 5217
Hi,
Have a problem with DTS-HD. Can't get audio from my Oppo BDP-83. With HDMI set to bitstreem or audo I can get DD5.1 audio out of the 608 but not DTS-HD. Have the 608 set to direct. DTS-HD shows on the Oppo but no audio.
Thank you.
