Originally Posted by
Yardl3y
So is the CT-150's volume really significantly lower than the LG LSB316? Or low in general for those that haven't tested the LG? Or was there something wrong with the one I tested? I'm gonna have to go to another BestBuy tomorrow because I don't understand how the CT-150 could have so much praise if it sounds like the one...
Eager to hear your thoughts. Thanks!
I'm reading this thread also wondering about the weak volume on my just purchased 150. Using a non-hd cable box to RCA in on a Panasonic, and optical or hdmi arc to the 150, the max volume sounds like it's turned halfway up. It's definitely not loud. A blu ray from a ps3 to the 150 using hdmi and
hdmi arc was reasonably loud at max, but not cranked up loud. (we were able to have normal, non-shouting conversations, my gf and I).
So, max loudness varies with the source, from what seems to be a half volume setting, to a loud but not very loud one. It's interesting that the volume goes to number 50. Why not 100 for 100%? It seems like there's a loudness governor on that prevents loudness from going above 50%.
I want to like and keep these speakers. But, they seem loudness hobbled. I read sporadic complaints like mine, yet also many positive reviews. Am I missing something? The room they're in is a small to medium size LR that's open with a small dining room. Is the trick to up the sw and center setting (and bass and treble)?
