Hey guys I'm getting ready to finish up a deployment overseas and coming home in January. I've been looking at getting the sony hc-tc150 or 300 forever and now i just noticed that they came out with the 550 model.
I've found the 550 model online for around $250-$300 and this is right in my price range of what i want to spend.
I'm using it as the main source of sound out of my living room flatscreen. I've got a 52 inch samsung tv on a tv stand. the reason for the sound bar is b/c the tv has its speaker on the bottom of the tv. i didn't think about it when i first bought it but now i notice that the sound reflects off the tv stand and really comes out distorted and muffled sometimes.
i think having a sound bar would totally fix the problem. i don't plan to use the speakers on the tv at all and have them turned all the way down.
i'm hooking up hdmi inputs from my satellite box, blue ray player and xbox 360. my living room is about 20x20 with high vaulted ceilings.
There really is only a difference of about $100 between the 150 and 550 models. So can someone steer me which direction to go? I'm pretty much settled on getting the 550 model unless anyone has any negative info about it to give me.
From all the reviews i've gone over it seems it is a quality sound bar that even has the wireless subwoofer and built in fm tuner.
thanks for all the advice and i'm really looking forward to getting back home and buying this.
